1999
rweissonm
Beginner
Cisco 2800 - dual WAN issue
Hi guys, I have 2 internet connections that will be providing services to different servers, the idea is that both connections can work at the same time, I will be sending some traffic through WAN1 and a different independent traffic through WAN2 all the traffic will be directed to the same LAN but to different servers/workstations depending on the request. I was able to configure my router (Cisco 2800) to work with both ISPs but they are working only as a backup connection (wan2 works only if wan1 is down and viceversa). Below is the configuration of my router, if you have any suggestion please let me know.
interface GigabitEthernet0/0.20
description WAN2
encapsulation dot1Q 20
ip address Y.Y.Y.Y 255.255.255.252
ip nat outside
no snmp trap link-status
interface GigabitEthernet0/0.50
description WAN1
encapsulation dot1Q 50
ip address X.X.X.X 255.255.255.240
ip nat outside
interface GigabitEthernet0/1
description LAN
ip address 192.168.1.247 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 WAN1
ip route 0.0.0.0 0.0.0.0 WAN2
ip http server
no ip http secure-server
ip nat inside source route-map Comcast20 interface GigabitEthernet0/0.20 overload
ip nat inside source route-map Comcast50 interface GigabitEthernet0/0.50 overload
ip nat inside source static tcp 192.168.1.105 80 interface GigabitEthernet0/0.20 80
ip nat inside source static tcp 192.168.1.105 22 interface GigabitEthernet0/0.20 22
ip nat inside source static tcp 192.168.1.105 3389 interface GigabitEthernet0/0.20 3389
ip nat inside source static tcp 192.168.1.61 3389 x.x.x.x 3389 route-map Cisco50 extendable
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
access-list 150 permit ip 192.168.1.0 0.0.0.255 any
route-map Comcast50 permit 10
description Comcast Link 50 Mbps
match ip address 150
match interface GigabitEthernet0/0.50
route-map Comcast20 permit 10
description Comcast Link 20 Mbps
match ip address 120
match interface GigabitEthernet0/0.20
5 REPLIES 5
germain85
Beginner
Hi Rafael,
I guess you should
1- use two access-list for diffrent subnet. One for the traffic you want to send out WAN1 and a second for the traffic you want to send out WAN2. Your access-list 120 and 150 matches same subnet, then same traffic.
2- Your route-map. i guess you should set the outgoing interface not match the outgoing interface as you did.
3- Then you apply corectly each access-list for the NAT it will work correctly
4- (optional) If you want now to configure a failover, then you can add ip sla
Germain
Rafael,
I see no issues with configuration, this is correct way of load balaning when using dual WAN links.
Can you please share the following o/p?
sh ip route 0.0.0.0
show ip nat tran
Amit Aneja
Hi Rafael,
Have a look on this, i mean it can help you: https://supportforums.cisco.com/docs/DOC-8313
Amit, below is the output you requested
Routing entry for 0.0.0.0/0, supernet
  Known via "static", distance 1, metric 0, candidate default path
  Routing Descriptor Blocks:
    Y.Y.Y.Y, permanent
      Route metric is 0, traffic share count is 1
  * X.X.X.X, permanent
____________________________________________________________
sh ip nat translation:
Pro Inside global      Inside local       Outside local      Outside global
tcp X.X.X.X:3389 192.168.1.5:3389           ---                     ---
tcp Y.Y.Y.Y:3389 192.168.1.134:3389     ---                     ---
Germain:
I'm working in your proposed solution right now, I will keep you posted.
Rafael
