Highlighted
Beginner
Cisco 2901 and BT Infinity
We have recently had BT Infinity installed, we are swapping out the homehub for a 2901 and an ASA.
I  am having some trouble with the router side of the config.  My  interface shows as up and is getting an IP address but I cannot get to  the internet, I can run a trace that appears to be getting out but it  dies before getting to the destination.
Any help would be greatly appreciated.  I have attached our config and the trace results.
1 ACCEPTED SOLUTION
Highlighted
Change this:
ip nat inside source route-map infinity interface Dialer1 overload
to:
ip nat inside source list infinity interface Dialer1 overload
7 REPLIES 7
Highlighted
Enthusiast
Roger, your configuration is missing 'ip nat inside' on the internal interface and a NAT statement.
interface GigabitEthernet0/0
ip nat inside
ip access-list extended NAT-ACL
permit ip 10.10.10.0 0.0.0.255 any
permit ip 192.168.0.0 0.0.255.255 any
ip nat inside source list NAT-ACL interface Dialer1 overload
Highlighted
Thanks for that, I can now ping and trace from the router.  But strangely i have no external access from my pc when connected to the 10.10.10.0 network.
If I run a tracert from my pc the connection goes as far as the router and dies.
Highlighted
Can you post an updated "show run" and include a "show ip route" please?
You can also configure "debug ip nat" on the router and retry your connection and post the debug here.
Highlighted
Hi, please see the updated config and routing table.
I think I have a NAT issue as show ip nat translation has no results
sho ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Dialer1
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.10.10.0/24 is directly connected, GigabitEthernet0/0
L        10.10.10.1/32 is directly connected, GigabitEthernet0/0
      81.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        81.137.28.200/29 is directly connected, Dialer1
L        81.137.28.206/32 is directly connected, Dialer1
C        81.148.0.1/32 is directly connected, Dialer1
S     192.168.0.0/16 [1/0] via 10.10.10.2
sho run
Building configuration...
Current configuration : 3747 bytes
! Last configuration change at 10:06:07 PCTime Fri Jul 26 2013 by admin
! NVRAM config last updated at 10:06:08 PCTime Fri Jul 26 2013 by admin
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname *****
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret *****
enable password *****
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime 0 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
no ip source-route
ip cef
no ip bootp server
no ipv6 cef
license udi pid CISCO2901/K9 sn FCZ16509433
username
controller VDSL 0/0/0
ip tcp synwait-time 10
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
description BT Infinity Connection$ES_LAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no mop enabled
interface Ethernet0/0/0.101
encapsulation dot1Q 101
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
ip address 81.137.28.206 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname *****
ppp chap password *****
ppp pap sent-username ***** password *****
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.0.0 255.255.0.0 10.10.10.2
ip access-list extended infinity
logging trap debugging
no cdp run
route-map infinty permit 1
match ip address infinity
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password *****
transport input all
scheduler allocate 20000 1000
end
Highlighted
Change this:
to:
Highlighted
Fantastic, that worked.
Is it possible to have multiple ip addresses on the dialer interface, we have a pool of 5 static addresses.
Highlighted
Yes, you can have mutliple addresses on an interface - just use the keyword "secondary" when adding them. If you just want to use multiple addresses for your NAT translations then configure a pool as per this link:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic4
