Cisco 2911 port gone bad?
Hi everyone,
I purchased a brand new Cisco 2911 Router and when connecting everything together I noticed an issue with my gi0/1.
When I issue a no shut on both interfaces the port Gi1/0/12 would intermittently blink amber once and then go off, and it would continue to do so and would never connect the interface.
Cisco 2911
interface GigabitEthernet0/2
no ip address
duplex full
speed 1000
end
GigabitEthernet0/1 is down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is 70ca.9b04.5131 (bia 70ca.9b04.5131)
  Description: CNETWORKS INTERNAL NETWORK
  Internet address is 17.2.34.2/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Auto Duplex, Auto Speed, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Cisco 3750G
interface GigabitEthernet1/0/12
switchport access vlan 801
switchport mode access
speed 1000
duplex full
spanning-tree portfast
end
GigabitEthernet1/0/12 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0019.5682.4d0c (bia 0019.5682.4d0c)
  Description: BELL EXTERNAL
  MTU 2000 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
     Received 0 broadcasts (0 multicasts)
     0 output errors, 0 collisions, 1 interface resets
I have yet to see any counters increase. I swapped out the cable several times with new Cat6 cables and still no luck. Any insight would be greatly appreciated. Would be unfortunately for this brand new, never opened device would have a dead port.
Thanks!
20 Replies 20
Leo Laohoo
Try this on the 3750G:
1.  Command:  test cable tdr interface GigabitEthernet1/0/12;
2.  Wait for 5 to 7 seconds;
3.  Command:  sh cable tdr interface GigabitEthernet1/0/12; and
4.  Post the output to #3.
I always seem to forget about that command;
Here is the output;
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/12  1000M Pair A     0    +/- 4  meters N/A         Short
                Pair B     0    +/- 4  meters N/A         Normal
                Pair C     1    +/- 4  meters N/A         Normal
                Pair D     0    +/- 4  meters N/A         Normal
And there is your culprit.  The cable coming from the switch is faulty.
Thank's for the input, however trying over at least 10 Cables, most of them taken out of the original packaging and made by hand will display the same output;
Just plugged in a working cable from my desktop to these two ports;
Gi1/0/12  1000M Pair A     1    +/- 4  meters N/A         Normal
                Pair B     3    +/- 4  meters N/A         Short
                Pair C     2    +/- 4  meters N/A         Normal
                Pair D     2    +/- 4  meters N/A         Normal
and now another;
This time plugging it into port Gi1/0/9 to show the port won't matter;
Gi1/0/9   auto  Pair A     0    +/- 4  meters Pair A      Short
                Pair B     0    +/- 4  meters Pair B      Normal
                Pair C     0    +/- 4  meters Pair C      Normal
                Pair D     0    +/- 4  meters Pair D      Normal
One more interesting peice of information -- when leaving everything as auto negotiate for the ports and continuously typing "show int g1/0/9 status" or "show int g1/0/12 status" this kind of thing popped up
Port      Name               Status       Vlan       Duplex  Speed Type
Gi1/0/9   CND005             connected    300        a-half  a-100 10/100/1000BaseTX
Than would disconnect right away
How is the router and 3750G connected?  Is it by a single cable or does it go through a series of jacks?
What IOS is your 3750G running?
If I remembered correctly, TDR results on IOS version 15.0(1)SE2 are not to be trusted.   The TDR result on this IOS doesn't get reset when you re-test the port.  You'll need to reboot the appliance just to clear the test result table.
Directly connected via Straight Through cable;
3750G is running the following;
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24PS     15.0(1)SE1            C3750-IPSERVICESK9-M
it's weird, because all other ports on the Router are connected and working absolutely fine. Gi0/0 and Gi0/2
Gian,
If you have a spare 3750G or a 2960S, load 15.0(2)SE2 and try the TDR again on the cables you've tested with the older IOS.
Sure I have a large lab being build right now.
I'll get one of my 2960's loaded with 15.0(2)SE2, would 15.0(2)SE3 be alright? Just recently downloaded the newest release of the 2960 IOS.
Holy sh1t!  NO, DO NOT USE IOS version 15.0(2)SE3!
There's a major bug with 15.0(2)SE3 and TACACs.  Read our discussion here
Thanks for the heads up, i'll read that discussion.
I loaded 15.0(2)SE2 and here is the output;
Fa0/1     auto  Pair A     N/A                N/A         N/A
                Pair B     N/A                N/A         N/A
                Pair C     N/A                N/A         Not Supported
                Pair D     N/A                N/A         Not Supported
Errrr ... Don't use a FastEthernet port, please.
Sorry about that; here is the output on Gi0/1 on that same switch;
Gi0/1     auto  Pair A     8    +/- 2  meters N/A         Short
                Pair B     N/A                N/A         Normal
                Pair C     N/A                N/A         Normal
                Pair D     N/A                N/A         Normal
Still calling it a "short" on the most important pair.
Ok, here's one way of testing if this is a faulty test or not.
Connect the same cable to your laptop.  If the laptop's NIC doesn't light up, the test is accurate ... to a certain degree.
Gi0/1     1000M Pair A     0    +/- 10 meters Pair A      Normal
                Pair B     0    +/- 10 meters Pair B      Normal
                Pair C     0    +/- 10 meters Pair D      Normal
                Pair D     0    +/- 10 meters Pair C      Normal
connected to my Laptop from the switch.
and when connected to the router from my laptop
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
