CISCO 2921 & BT Infinity with static IPs
C26
I'm not hugely experienced with Cisco routers but I've managed to configure a Cisco 2921 with BT Infinity which works fine. I can access the web/browse etc.
The only thing I'm struggerling with, is my BT package has static IPs currently the BT Home hub dials with PPOE and the static IPs on the hub appear to be a virtual interface. Does anyone know how to configure this similar style setup on a Cisco router?
Conf below;
Current configuration : 3570 bytes
! Last configuration change at 11:27:34 UTC Sun Apr 8 2018 by mroot
! NVRAM config last updated at 11:17:34 UTC Sun Apr 8 2018 by mroot
version 15.1
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname router
boot-start-marker
boot-end-marker
no logging console
enable secret 4 bKeS4xiYXaJxSPFOy2jnfzOvVRFm80AdocXk.8g4BYE
no aaa new-model
memory-size iomem 25
no ipv6 cef
ip source-route
ip cef
ip domain name domain.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
license udi pid CISCO1921/K9 sn FCZ170595H6
username mroot privilege 15 secret 4 mOA83nec.Q62OjRrUlRfSx3EZxHay2wbwsJ8jRpOd5c
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 no ip route-cache
 ip tcp adjust-mss 1452
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface GigabitEthernet0/0.1
 encapsulation dot1Q 101
 ip virtual-reassembly in
 no ip route-cache
interface GigabitEthernet0/1
 ip address 10.1.10.50 255.255.255.0
 ip nat inside
 ip tcp adjust-mss 1350
 duplex auto
 speed auto
interface Dialer1
 ip address negotiated
 ip access-group 101 in
 no ip unreachables
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp chap hostname login@btconnect.com
 ppp chap password 7 14071E1E01063F38302D2164
 ppp pap sent-username login@btconnect.com password 7 044B07130223595D1D1C1746
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.1.0.0 255.255.0.0 GigabitEthernet0/1
access-list 1 remark INTERNET-ACCESS
access-list 1 permit 10.1.0.0 0.0.255.255
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip 255.0.0.0 0.255.255.255 any
access-list 101 deny   ip 224.0.0.0 7.255.255.255 any
access-list 101 deny   ip host 0.0.0.0 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   udp any any range 33400 34400
access-list 101 permit icmp any any net-unreachable
access-list 101 permit icmp any any host-unreachable
access-list 101 permit icmp any any port-unreachable
access-list 101 permit icmp any any packet-too-big
access-list 101 permit icmp any any administratively-prohibited
access-list 101 permit icmp any any source-quench
access-list 101 permit icmp any any echo-reply
access-list 101 permit tcp any any established
access-list 101 permit udp any any
control-plane
line con 0
 logging synchronous
 login local
line aux 0
 logging synchronous
 login local
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input ssh
line vty 5 1370
 logging synchronous
 login local
 transport input ssh
scheduler allocate 20000 1000
end
0 Replies 0
