Cisco 3750 Switch Problem: POST: inline power post failed for ALL ports
sarifulcisco
Need Help with WS-C3750-48PD-S switch.
We have a switch that started functioning abruptly.
The switch boots normally but after POST, however, all Copper ports on the switch remains amber instead of blinking green.
We then captured the information during while boot and during POST.
Our log file displays:
POST: Inline Power Controller Tests : Begin
POST: inline power post failed for port 0
POST: inline power post failed for port 47
for all ports.
what sort of problem is this? Can anybody suggest.
Note: Attached the log file for convenience.
Waiting for response,
Sariful, Dhaka, Bangladesh
Vignesh Rajendran Praveen
Hi Sariful,
The Switch has developed a permanent hardware failure and needs to be replaced at the earliest. Kindly do the needful.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
Leo Laohoo
There's nothing you can do.  The switch needs to be RMAed.
deepuramesanv
hi,
its better to return back that switch to your service partner.
