Cisco 3845 Modules.
isspl2006
Want to know whether HWIC-4T [Serial Synchronous Port] is supported in Cisco 3845V3PN Router.
amit-singh
Level 8
Level 8
isspl2006
I had a check in cisco product configurator tool, and this tool does not add HWIC-4T when 3845 V3PN bundel is selected. The point is to know whether the HWIC slots are full when this bundel is purchased or we can add this module later on.... There is some confusion.
I have just checked it in the product configuration tool and yes it is not listed there.
Ad per the product explanation 3845 V3PN bdle,AIM-VPN,PVDM2-64,CCME-240,AdvIPServ,64F/256D
concers this doesnot have any HWIC/WIC module inlcuded that means we can use any HWIC/WIC card in the router later.
Its strange to me as well why it is not listed there, but I am pretty sure that you still will be able to use it in the router. You have got WIC-2t listed there under the HWIC/WIC option and you can take that one if you want.
HTH,
-amit singh
Thank You Amit for your help and consideration.
