04-02-2015 07:08 AM - edited 03-05-2019 01:09 AM
when i start the switch 4948 and access via console the switch4948 is directly going in rommon 1 >
04-02-2015 07:33 AM
please log the booting process in a file & paste here to check the exact reason, generally it happens when device don't have any IOS file or IOS file is corrupt or somehow device not able to load the IOS in the DRAM.
- Ashok
Please rate the useful post or mark as correct answer as it will help others looking for similar information
04-02-2015 07:44 AM
Thanks for your reply
when i apply this commands configreg
rommon 1 >set
PS1=rommon ! >
Fa1Enable=1
RommonVer=12.2(31r)SGA2
DebugCallHome=00000
BOOTLDR=bootflash:cat4500-entservicesk9-mz.150-2.SG4.bin
BootedFileName=bootflash:cat4500-entservicesk9-mz.150-2.SG4.bin
RET_2_RTS=20:59:14 UTC Wed May 21 2014
ConsecPostPassedCnt=69
RET_2_RCALTS=
DiagMonitorAction=Normal
BOOT=
ConfigReg=0x2102
rommon 2 >configreg
monitor: command "configreg" not found
rommon 3 >ConfigReg
monitor: command "ConfigReg" not found
rommon 4 >confreg
Configuration Summary :
=> load rom after netboot fails
=> console baud: 9600
=> autoboot from: commands specified in 'BOOT' environment variable
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]: n
enable "use net in IP bcast address"? y/n [n]: n
disable "load rom after netboot fails"? y/n [n]: n
enable "use all zero broadcast"? y/n [n]: n
enable "break/abort has effect"? y/n [n]: n
enable "ignore system config info"? y/n [n]: y
change console baud rate? y/n [n]: n
change the boot characteristics? y/n [n]: n
=> ignore system config info
do you wish to save this configuration? y/n [n]: y
You must reset or power cycle for new configuration to take effect
Again i am going rommon mode
04-02-2015 07:38 PM
Syed,
Post the entire bootup process. We all want to see WHY the appliance keeps going into ROMmon.
