Cisco 5915 ESR Router Boot Issue
hamid khan
Hi All,
I have got Cisco 5915 Mobile Router it has boot issue.
When powered on it cant be accessed via console cable and status light is glowing green and blue.
Need help in regards.
With Best Regards
balaji.bandi
looks like your router is booting ROMMON, check the IOS if exist on flash or not, if yes, make sure you're pointing to it properly.
Moaz Elzhrawey
Solutions Architect, CCIE 2x RS | DC, VCP 3x NV | DCV | DTM
+966 596822551
I cannt access the router even through console cable, it just gives black screen and status light is glowing blue and green.
