Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 6500 -Traceback Error
dnspacket1
Dear All,
I have  a Cisco 6500 with dual sup VS-S720-10G & Switch is not in VSS mode.
Version is s72033-advipservicesk9_wan-mz.122-33.SXH7.bin
I am continously getting the following error
%SYS-SPSTBY-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (1/1),process = Check heaps.-Traceback= 4078FE24 4079161C 40793230 4079348C 407594A4 40759490 %SYS-SPSTBY-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (1/1),process = Check heaps.-Traceback= 4078FE24 4079161C 40793230 4079348C 407594A4 40759490
%SYS-SPSTBY-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (9/7),process = Check heaps.-Traceback= 4078FE24 4079161C 40793230 4079348C 407594A4 40759490%SYS-SPSTBY-3-CPUHOG: Task is running for (2000)msecs, more than (2000)msecs (9/7),process = Check heaps.-Traceback= 4078FE24 4079161C 40793230 4079348C 407594A4 40759490
Also I am unable to issue write mem command. When  I execute, following error appears.
Unable to read configuration. Try again later.
Can anyone please update me what could be the issue
Deva
Richard Burts
Deva
When a syslog message includes Traceback information it is always the result of a software problem. I do not know what particular software problem this would be, but it is sure that there is some software problem. If this is covered by a maintenance contract then I would suggest opening a case with Cisco TAC since they have tools to intestigate the traceback.
Rick
Rick
