02-24-2016 10:46 PM - edited 03-05-2019 03:25 AM
Hi!
I am getting an issue with a Cisco 6509-E switch as it goes to rommon mode each time it is restarted.
From the rommon mode, the switch can only be booted when using the IOS from the PCMCIA card (disk0).
Following successful booting from disk0, switch goes to rommon upon reboot.
bootflash is also not available and does not contain a valid magic number.
See below output:
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Clearing autoboot state machine
Reading monitor variables from NVRAM
Reset reason 0x8ffff.
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
rommon 1 > dev
Devices in device table:
id name
bootflash: boot flash
disk0: PCMCIA Disk 0
disk1: PCMCIA Disk 1
eprom: eprom
rommon 2 > dir bootflash:
Read cis from dev 1 error (-6)device does not contain a valid magic number
dir: cannot open device "bootflash:"
rommon 3 > dir disk0:
Directory of disk0:
4 80102916 -rw- s72033-ipservicesk9_wan-mz.122-18.SXF13.bin
rommon 4 > set
PS1=rommon ! >
BSI=0
ACL_DENY=0
PF_REDUN_CRASH_COUNT=0
LOG_PREFIX_VERSION=1
RANDOM_NUM=2090119228
SLOTCACHE=cards;
RET_2_RTS=23:49:19 UTC Fri Oct 30 2015
RET_2_RCALTS=1446248958
?=0
rommon 5 > boot disk0:s72033-ipservicesk9_wan-mz.122-18.SXF13.bin
Loading image, please wait ...
After successful booting:
Router#sh bootvar
BOOT variable =
CONFIG_FILE variable =
BOOTLDR variable =
Standby is not present.
Router#remote command switch sh bootvar
BOOT variable does not exist
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x8000
02-24-2016 11:06 PM
Router#sh bootvar
BOOT variable =
Do this:
config t
boot system flash disk0:
end
wr
02-26-2016 03:34 AM
Hi Leo!
I have executed the commands as mentioned.
However after saving and reloading, the Cisco 6509 goes back to rommon mode.
Please see below output:
rommon 1 > boot disk0:s72033-ipservicesk9_wan-mz.122-18.SXF13.bin
Router#show bootvar
BOOT variable =
BOOTLDR variable =
Router(config)#boot system flash disk0:s72033-ipservicesk9_wan-mz.122-18.SXF13.bin
Router#show bootvar
BOOT variable = disk0:s72033-ipservicesk9_wan-mz.122-18.SXF13.bin,1;
BOOTLDR variable =
Router#remote command switch show bootvar
When rebooting, the Cisco 6509 goes back to rommon.
rommon 1 > set
PS1=rommon ! >
SLOTCACHE=cards;
BOOT=disk0:s72033-ipservicesk9_wan-mz.122-18.SXF13.bin,1;
?=0
BSI=0
ACL_DENY=0
RANDOM_NUM=1278066608
RET_2_RTS=01:21:53 UTC Sat Oct 31 2015
RET_2_RCALTS=1446254512
Need to issue boot disk0:s72033-ipservicesk9_wan-mz.122-18.SXF13.bin for the Cisco 6509 to boot successfully.
Another observation is that when shutting down the Cisco 6509 and powering again the set command in rommon is as follows:
System Bootstrap, Version 8.1(3)
Copyright (c) 1994-2004 by cisco Systems, Inc.
Clearing bss
Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
Reset reason 0xffff.
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
rommon 1 > set
PS1=rommon ! >
02-26-2016 03:55 AM
The configuration register on the SP (0x8000 in your case) can be fixed by "conf t / config-register 0x2102 / wr mem" (which updates it on both SP and RP).
However, the corrupted NVRAM after power-offs is a good hint that the CR1225 3V lithium battery on the supervisor has lived its life - I've been in this situation, and replacing that battery fixed things for me.
Also happened to other people: https://supportforums.cisco.com/discussion/10513296/sup720-sp-rommon-looses-confreg-and-config-nvram-corrupted
05-25-2016 03:49 AM
That's correct.
I replaced that CR1225 3v lithium battery and it solved the issue.
Many thanks.
