12-03-2007 03:00 AM - edited 03-03-2019 07:46 PM
Hi, I've got an error message saying enqueued to process level.I am trying to find something in the cisco site but i do not seem to succeed anything. Does anyone know what this error means?
12-03-2007 03:53 AM
Please report the message in full, and the circumstances under which it is occurring.
12-03-2007 04:31 AM
the platform is Cisco 7206VXR running Version 12.3(9) IOS SOFTWARE. The error message is reapeating :
Version 12.3(9) and it appears in the log.
Dec 3 14:30:00: Enqueued to process level.
Dec 3 14:30:01: Enqueued to process level.
etc....
12-03-2007 05:25 AM
Some packets are being handled at process level instead of interrupt time.
This can be due to configuration, features enabled, or packet properties.
In any case the message should not be printed.
Suggest you upgrade to latest maintenance for 12.3 and chances are the message will go away.
12-03-2007 05:30 AM
i see the following in the configuration :
ip flow-cache timeout inactive 30
ip flow-cache timeout active 1
could this have to do anything with the error?
12-03-2007 05:42 AM
Not necessarily. This type of spurious messages without a proper identification, are caused by programmers forgetting to remove debugging output. This is why upgrading is recommended.
10-28-2008 08:38 AM
I am now seeing the same issue in 12.4(15) on a 7201 ;
IPFLOW: Error sending export packet: Enqueued to process level
IPFLOW: Sending UDP export pak 948646533 to 10.10.10.10 port 9995 reason 2
Can you be more specific on the cause ?
