Cisco 7200VXR
veils1de123
I'm looking to get a couple of Cisco 7204VXR's with NPE-400 or NPE-G1's
With both of these NPE's what version of IOS should I be looking for, which is stable and good for IP Routing?
I'd like to know on past experiences or is there a document which explains what each IOS includes or their target market is?
I.E -
c7200-ik9o3s-mx....
c7200-advipservicesk9-mz...
c7200-p-mz....
I'd like to know what the above ones stand for and which would be best suited for my requirements.
Sorry if this's in the wrong section!
vmiller
Level 7
Level 7
If you can, spring for the NPE-G2.
First, you need to identify what "features" you need to support.
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_bulletin0900aecd802d2ec7_ps5460_Products_Bulletin.html
there is a start.
Then, Which version of IOS to run. The newest is 15.x probably the most common is 12.x
All versions do IP routing, its the extras you need to consider.
