06-03-2017 07:50 PM - edited 03-05-2019 08:39 AM
hi
I recently update the firmware to "c7301-advipservicesk9-mz.152-4.S6.bin" everything worked fine until I did "show log"
I get the below error
*May 23 12:46:18.151: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 1200)) is not supported on this image.
Please issue "show diag" in fully loaded IOS image
to get the PA's information and verify if it is supported
by this image, a newer version may be needed.
*May 23 12:46:18.151: %PA-3-DEACTIVATED: port adapter in bay [1] powered off.
Router7301#sho diag
Slot 1:
Unknown (type 1200) Port adapter
Port adapter is disabled deactivated powered off
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Is there a way to fix this or do i have to revert back to my old 12.2 version of firmware.
Any help will be greatly appreciated.
06-03-2017 11:49 PM
as far as I recall, this message appears during boot and will not be relevant once the full IOS image is loaded. Which means, you can ignore the message.
I assume the adapter is working fine ?
06-06-2017 06:47 PM
Georg,
everything seem to be working fine after the full IOS load, I am not seeing any problem so should I be ignoring this message.
Leo
How to find out what share ports?
06-04-2017 12:06 AM
What kind of shared port adapter is this?
06-04-2017 01:28 PM
SA-VAM2+? What does "show bootvar" output?
This may help: https://lists.gt.net/cisco/nsp/20986
