08-20-2013 12:19 AM - edited 03-04-2019 08:49 PM
I need to understand exactly how the "bandwidth per slot", as specified in the various supervisor's documentation, is calculated. For example, RSP720 allow for 40Gbps / slot - is that simply the sum of IN+OUT traffic on all interfaces in the slot, or is it rather forwarding capacity (for example, if the same traffic enters one interface and exits another in the same slot, it is only counted once)?
Is there any "show ... counters"-like command that can tell me whether a slot has reached this bandwidth limit?
Thank you.
Solved! Go to Solution.
08-20-2013 04:06 AM
It is 40Gbps in, 40Gbps out. You can check the module fabric utilization using 'show platform hardware capacity fabric'
HTH,
Lei Tian
08-20-2013 04:06 AM
HTH,
Lei Tian
08-20-2013 04:53 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
To add to Lei's info, to obtain the RSP720's 40 Gbps (duplex) per slot, you need to have CEF720 line cards. Also with the RSP720, and a 7613, only slots 9-13 support 40 Gbps (slots 1-6 support 20 Gbps). (NB: BTW, with the 7600-S series, and a sup2T, all slots support 80 Gbps, including the 7613-S.)
