Cisco 827H ADSL Interface Capability
graemeporter
Hi guys,
Trying to find a quick bit of info about the Cisco 827H router.
Can someone tell me what the maximum downstream speed of the ADSL interface is?
I have one of these routers for home use, and am thinking of going for a faster DSL service - the 827H tells me I'm getting 2848 kbps downstream - just wondering if my 827H will be able to support the service being offered (up to 16 Mbit downstream, and I live less than 1 mile from my exchange), or if I should upgrade to a newer model.
Many thanks in advance,
Graeme
Giuseppe Larosa
Hello Graeme,
it will not support 16Mbps DS
from datasheet
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a0080092161.html#wp40570
support for
T1.413 ANSI ADSL DMT issue 2
•G.992.1 ITU G.DMT support
•G.992.2 ITU G.Lite support
•G.992.3 ITU G.hs ADSL type negotiation
But ADSL standards state
Technology ITU-standard
ADSL ANSI T1.413 Issue 2
ITU G.992.1 (G.DMT)
ITU G.992.2 (G.Lite)
ADSL2 ITU G.992.3/4
ITU G.992.3 Annex J
ITU G.992.3 Annex L
ADSL2+ ITU G.992.5
ITU G.992.5 Annex M
So you will need another router for ADSL2 or better
Hope to help
Giuseppe
Giuseppe Larosa
Hello Graeme,
from datasheet
support for
ITU G.992.1 (G.DMT)
ADSL2 ITU G.992.3/4
ITU G.992.3 Annex J
ITU G.992.3 Annex L
ADSL2+ ITU G.992.5
ITU G.992.5 Annex M
Hope to help
Giuseppe
Thanks very much Giuseppe!
Anyone got an 877 they wouldn't mind not having any more ... ? :)
Kind regards
Graeme
