Cisco 837 ADSL Router (WAN Issue)
reb999000
To All,
I  am having an issue attempting to  connect to my ISP Bt  Internet (ISP Provider in UK) I have copy/pasted the input from show  running-config, please view the input and please point out to me of anything incorrect?
Router#show run
Building configuration...
Current configuration : 1628 bytes
version 12.3
no service pad
hostname Router
enable secret 5 $1$xJ8e$hhR8op6B/LxC4bXNTkI0d.
no aaa new-model
ip subnet-zero
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description Ethernet
ip address 192.168.1.1 255.255.255.0 (Default Gateway)
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
pvc 0/38
   encapsulation aal5mux ppp dialer
   dialer pool-member 1
dsl operating-mode auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname ***************@adsl.btinternet.com
ppp chap password 0 adsl**************
ppp pap sent-username *************** password 0 **************
ppp ipcp mask request
ppp ipcp address accept
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
access-list 1 permit 192.168.0.0 0.0.0.255
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Router#
Here is also an input from show ip int brief:
Router#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
Dialer0                    172.16.68.234   YES IPCP   up                    up
Ethernet0                  192.168.1.1     YES NVRAM  up                    up
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              unassigned      YES unset  down                  down
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
I would br very greatful of any help in resolving this problem
Much Appreciated!
Bob.
18 Replies 18
ok put them back in then. I really don't understand why you get this private IP, you should provide your ISP with the debug output and ask them what is happening.
Regards.
Alain
Before escalating to your ISP, could you add 'ppp ipcp default route' together with the 2 other commands under the dialer interface. Do a shut/no shut on the ATM port and try again.
johnlloyd 13,
I have reconfigured the two other ppp commands back into the d0 interface, but will not accept the "ppp ipcp default route" command as you can see in my below input:
Router#
%LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed state to up
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#int d0
Router(config-if)#
%DIALER-6-BIND: Interface Vi2 bound to profile Di0
%LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
%LINK-3-UPDOWN: Interface ATM0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
Router(config-if)#
Router(config-if)#ppp ipcp default route
% Invalid input detected at '^' marker.
Router(config-if)#ppp ipcp mask request
Router(config-if)#ppp ipcp address accept
Router(config-if)#
Router(config-if)#exit
Router(config)#exit
Bob.
this feature is only available in  12.3(11)T and 12.4 images.
I wonder how it could prevent you from being given a private IP
Regards.
Alain
