CISCO 871W cannot ping external router interface
jprophet64
Good morning everyone,
I hope someone here could assist me with the situation I am facing, I am a network administrator who has been assigned the task of adding a secondary router to a redundant backup third party provided internet circuit. This router will serve two-fold firstly it will serve out dhcp addresses through a dhcp pool and secondly it will accomodate 2 Unifi AP access points. I'll show my config below but the end result is I cannot ping the outside router interface that the ISP has provided which ultimately should allow me to get on the internet.  My config is below:
CLTCHIEF2#show run
Building configuration...
Current configuration : 1934 bytes
! Last configuration change at 17:52:47 UTC Sun Mar 3 2002
version 15.1
no service pad
service password-encryption
hostname CLTCHIEF2
boot-start-marker
boot-end-marker
enable secret 5 $1$fMm.$fVzzs3q6pnSM6avr03Nho1
enable password 7 12211D0E081115
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 172.16.102.1 172.16.102.99
ip dhcp excluded-address 172.16.102.151 172.16.102.254
ip dhcp pool CLT2WIRELESS
   network 172.16.102.0 255.255.255.0
   default-router 172.16.102.1
   domain-name INTERNAL.COM
   lease 7
ip cef
no ip domain lookup
bridge irb
interface FastEthernet0
interface FastEthernet1
 shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 description WAN INTERFACE
 ip address 50.58.80.82 255.255.255.252
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface Dot11Radio0
 no ip address
 shutdown
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
 54.0
 station-role root
interface Vlan1
 description VLAN WIRED AND WIRELESS
 no ip address
 no ip redirects
 bridge-group 1
interface BVI1
 description VIRTUAL BONDED INTERFACE
 ip address 172.16.102.2 255.255.255.0
 no ip redirects
 no ip unreachables
 ip nat inside
 ip virtual-reassembly max-reassemblies 1024
 ip tcp adjust-mss 1360
 load-interval 30
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 150 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 172.16.102.1
ip route 0.0.0.0 0.0.0.0 50.58.80.81
access-list 150 remark NAT TRANSLATIONS
access-list 150 permit ip 172.16.102.0 0.0.0.255 any
snmp-server community public RO
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 password 7 07173955541300
 login
 transport input all
end
Does this config look right?
Thank-you.
53 Replies 53
Richard Burts
I wonder why you have two default routes
I understand the second one which will direct traffic to the provider router connected to FastEther0 but am puzzled about the default route with 172.16.102.1 as the next hop. In this config the router will try to use both default routes. It seems to me that it would be better logic if one were primary and the other was a backup route.
But I do not think that this has anything to do with whether the router can ping the external router or not. Would you post the output of show ip interface brief from the router? Also please post the output of show arp (or maybe show ip arp) from the router.
Rick
Rick
Here is the ip int brief you wanted:
CLTCHIEF2#show ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
BVI1                       172.16.102.2    YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    up
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES NVRAM  up                    up
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      50.58.80.82     YES NVRAM  up                    up
And here is the arp output.
CLTCHIEF2#show ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  50.58.80.82             -   001e.4ac3.7ccf  ARPA   Vlan1
Internet  172.16.102.2            -   001e.4ac3.7ccf  ARPA   BVI1
Another problem I have is everytime I introduce the BVI I loose my dhcp functionality; it comes up on my laptop with limited connectivity.
Thank-you.
rizwanr74
Level 7
Level 7
Hi there,
Please remove this static route: "ip route 0.0.0.0 0.0.0.0 172.16.102.1"
You cannot have two default-route point to two different ip-addresses and so remove the above and try it again.
thanks
ok removed that line will report what the result is but until I get my dhcp problem resolved I wont be able to use the ping command with any success.
I disagree with the statement that you "cannot" have two default routes to two different IP addresses. You absolutely can have this. The real question here is whether you "should" have this. Until we hear from the original poster explaining why it is configured this way we do not know whether it should or not be configured this way.
The output of show arp is informative. The router sees its own MAC address but does not see the MAC address of the provider router This is why ping was not working. The fact that we are not learning the MAC of the provider router indicates that either there is some problem at layer 1 or 2 or there may be a misconfigured IP address. Since the interface shows as up/up it would seem that layer 1 and 2 are probably working.
Rick
Rick
So based on that here is my question, when you plug in a cable to FE4 (WAN) to the provider router interface which in this case is G0/1 shouldnt fe4 interface in the ios have an ip assigned to it so that the internet can be reached?
The configuration you posted and the "sh ip int brief" don't match ie. the 50.x.x.82 IP is assigned to different interfaces.
So which is it meant to be ?
Jon
Here is the reconfigured config, I have removed the bridging based on the fact that I dont intend on using the built in wireless.
CLTCHIEF2#show run
Current configuration : 1624 bytes
! Last configuration change at 00:26:34 UTC Fri Mar 1 2002
version 15.1
no service pad
hostname CLTCHIEF2
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
   lease 7
ip cef
no ip domain lookup
 ip nat outside
 duplex auto
 speed 100
 no ip address
 shutdown
 54.0
 station-role root
interface Vlan1
 no ip address
 no ip redirects
no ip http server
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
Okay, couple of things -
1) you need to assign 172.16.102.1 to an interface otherwise your client access  won't work.
2) can you try pinging the ISP address again and then repost -
"sh ip arp"
"sh ip int br"
Jon
Jon,
Can you give me for an example as far as assigning 172.16.102.1 which I understand is the default gateway for my internal network to an interface? Are you referring to a virtual interface such as a vlan?
From config mode -
int vlan 1
ip address 172.16.102.1 255.255.255.0
then do a "sh ip int brief" to make sure it is up/up.
Jon
Yes it would on vlan 1. It would look something like
interface vlan 1
Have you tried to ping the external router from the 871?
Rick
Rick
Ok things are starrting to look up now, I am now getting served an ip address through the dhcp service now all I need to do is add the route to get out to the internet.
Now as far as fa4 my isp gave me an ip address of 50.58.80.82 to use should I tie that to fa4 as along with the dns info?
Updated config
Current configuration : 1373 bytes
! Last configuration change at 00:33:40 UTC Fri Mar 1 2002
version 15.1
no service pad
hostname CLTLVLTHREE
boot-start-marker
boot-end-marker
enable secret 5 $1$b126$CBurGrg/NkVtK63I7p4fg.
enable password 7 05331E163B5657
no aaa new-model
dot11 syslog
ip source-route
no ip routing
ip dhcp pool CLTLVL3
   domain-name CLTINTERNAL.COM
   lease 7
no ip cef
 shutdown
 shutdown
 shutdown
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
 no ip address
 no ip route-cache
 shutdown
 54.0
 station-role root
interface Vlan1
 no ip route-cache
no ip http server
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 password 7 1111011C0D0812
 login
 transport input all
end
Did you just clear the whole configuration because you don't have an IP on fa4 and all your NAT configuration has gone ?
So -
1) enable routing ie. "ip routing"
2) configure fa4 with 50.x.x.82 and add a default route to 50.x.x.81 assuming these are the actual IPs.
Note this a public forum so can you go through your posts in this thread and do as it have done with the public IPs.
3) add your NAT rules back in
Then from your router if you can ping the ISP address try connecting from a client.
Edit - DNS settings depends on whether you have any DNS servers internally. If not your ISP should have given you some and you need to include these in your DHCP pool configuration so your clients get them with their IP address.
Jon
