ā09-12-2017 09:15 PM - edited ā03-05-2019 09:07 AM
i have configure cisco 881 as below, clients can access internet work well, but video conference cannot call in/out could you please help to reivew and as advise.
ip name-server 203.144.128.194
ip cef
no ipv6 cef
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description WAN IP
ip address XXX.XXX.29.94 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
interface Vlan1
description LAN
ip access-group 101 in
ip nat inside
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 101 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 XXX.XXX.29.93
access-list 101 remark Verizon
access-list 101 permit ip 65.210.41.0 0.0.0.255 any
access-list 101 permit ip host 63.97.112.115 any
access-list 101 permit ip host 63.97.112.116 any
access-list 101 remark Level3
access-list 101 permit ip 207.218.87.0 0.0.0.255 any
access-list 101 permit ip 209.130.193.0 0.0.0.255 any
access-list 101 remark DNS
access-list 101 permit ip host 203.144.128.194 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
Solved! Go to Solution.
ā09-13-2017 11:58 PM
add the line below to your configuration:
ip nat outside source static xxx.xxx.29.94 192.168.1.10
ā09-13-2017 12:33 AM
ā09-13-2017 12:42 AM
ā09-13-2017 03:51 AM
with your current configuration, I don't see how your clients (on Vlan 1) can access the Internet, including video conferencing.
I have made a few changes to your configuration (marked in bold), try those and check if that makes a difference:
ip cef
no ipv6 cef
no ip address
no ip address
no ip address
no ip address
description WAN IP
ip nat outside
duplex full
speed 100
interface Vlan1
description LAN
no ip access-group 101 in
ip nat inside
ip http server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
end
ā09-13-2017 07:38 PM
ā09-14-2017 03:20 AM
Thank you for your help, I add this command already and will test it in next week then update.
