Cisco 881 half duplex issue
mze
cisco 881 issue
14 Replies 14
Richard Burts
Do you by any chance configure the speed of the WAN interface of 881?
Rick
thanks
Thanks for confirming that the 881 is auto for both speed and duplex. Can you tell us whether perhaps the ADVA configures the speed of its interface or is it set for speed auto?
Rick
Looks like there´s some misundestanding about IEEE 802.3u on this devices.  Did you try auto in both ends?
balaji.bandi
Can you post show version  - there may be some bug around some codes.
also post show run interface x/x and show interface x/x
Can you connect Laptop to Router see what is speed it negotiate on the same port ?
BB
thanks
Umesh Shetty
What you described in the first part of your products blem is an expected behaviour. When one end is set to auto negotiate and the other is hard coded the auto negotiate end does not have the means to know what the other end is set to and hence sets itself to the default i.e. half duplex
The other part is interesting though.
- If you did not use a Cross over cable , disabling auto negotiate can turn of mdix auto negotiate and hence the interface could be down.
- This can also be a cable issue ?
- Possibly also an interface problem.
Would be helpful if you send a show run of the interfaces. Also as earlier said can you connect the 881 to a laptop and see if auto negotiate works there ?
Like @Umesh Shetty, I agree too believe that's expected behavior, i.e. full-duplex<>auto results in auto using half-duplex.
For the latter, that might be whether the 881 supports auto-MDI/MDI-X, which on some other devices, when supported, requires port to be in auto mode.  I.e. on some device, if auto mode disabled, you need to use the correct cable (straight through, or cross over) to interconnect devices.
Your ADVA doesn't support auto?  (Almost, if not all, network hardware vendors, at least this century, recommend using auto<>auto.)
Hi thanks for reply
Hello
@mze wrote:
When setting the WAN interface on the 881 to fixed full duplex the connectivity gets  lost.
What exactly are you doing when setting this interface, Are you actually hardcoding both the speed AND duplex,  Also what speed is the ADVA box procurred at, the 881 seems to only support only fast ethernet?
Kind Regards
Paul
Hi thanks for reply
What is the ADVA interface set to ?
Full duplex .
If you force duplex on one side, you MUST force it on both sides. Forcing duplex means it doesn't participate in negotiations. Thereby the "auto" side MUST default to half because it gets no response to the negotiation request.
