Cisco 881-K9 out of box no active POE
I have a brand new router C881-K9 , I configured  it  and all is working properly . except the POE is not working .
this router has only one  12V power input , so I wonder if this will require an other dautercard fpr POE.
please any one can help on this
22 Replies 22
Leo Laohoo
Kindly post the complete output to the command "sh inventory raw".
Hello ,
here is the output
RO-Val-2#sh inventory raw
NAME: "C881-K9", DESCR: "C881-K9 chassis, Hw Serial#: FJC2125L0J8, Hw Revision: 1.0"
PID: C881-K9 , VID: V02, SN: FJC2125L0J8
NAME: "C881 Chassis Slot 0", DESCR: "C881 Chassis Slot"
PID: , VID: , SN:
NAME: "C881 Mother board on Slot 0", DESCR: "C881 Mother board"
PID: C881-K9 , VID: V02, SN: FOC21203QFU
NAME: "FastEthernet0", DESCR: "Gigabit Ethernet"
PID: , VID: , SN:
NAME: "FastEthernet1", DESCR: "Gigabit Ethernet"
PID: , VID: , SN:
NAME: "FastEthernet2", DESCR: "Gigabit Ethernet"
PID: , VID: , SN:
NAME: "FastEthernet3", DESCR: "Gigabit Ethernet"
PID: , VID: , SN:
NAME: "FastEthernet4", DESCR: "PQII_PRO_UEC"
PID: , VID: , SN:
NAME: "Container of powerSupply Containers", DESCR: "Container of powerSupply Containers"
PID: , VID: , SN:
RO-Val-2#
do you have the PoE card installed ? Also, I think you need a 48-V external power supply, which is an optional item when you order the router...
https://www.cisco.com/c/en/us/td/docs/routers/access/800/860-880-890/hardware/installation/memory/880FRU.html
No i do not have a card installed , but it is starange this router does not have power input for POE hawever if look to the picure i attached you see that cisco say the port F0 an F1 support POE
Output shows no PoE daughtercard (800-IL-PM-2).
yes I agree but this a c881-K9 router not c881SRST-K9.
in C881SRST-K9 we have that card and also a second power input for the POE
but for the model C881-K9 we have only 12v input
If you purchase the 800-IL-PM-2, the 150w power supply will be included.
I opened the router and mounted the card , but the router get stuck on the stage bellow and never starts until i removed the card .
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
Onboard devices &
buffer pools 0x022ECEC0
TOTAL: 0x022ECEC0
Rounded IOMEM up to: 34Mb.
Using 6 percent iomem. [34Mb/512Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.5(3)M4a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 06-Oct-16 14:23 by prod_rel_team
***** I2C bus 0xDF803100 hung, Board will be reset!
System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 2014 by cisco Systems, Inc.
Total memory size = 512 MB
Field Upgradeable ROMMON Integrity test
_______________________________________
ROM: Digitally Signed Production Software
C881-K9 platform with 524288 Kbytes of main memory
Main memory is configured to 32 bit mode
Upgrade ROMMON initialized
IOS Image Load Test
___________________
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################# [OK]
*** No sreloc section
***** I2C bus 1 hang recovery failed!
Please collect following I2C register trace for analysis!!
A1000000 00310C81 01310C81 013108A0
00310880 01310800 013108A0 003108A0
00310C81 00311000 01310880 00311000
01310820 013108A0 00310C81 01310C81
013108A0 003108A0 00310C81 00311000
01310880 00311000 01310820 013108A0
00310C81 01310C81 013108A0 003108A0
01310820 013108A0 00000000 00000000
TYPE MEMORY_REQ
Onboard devices &
TOTAL: 0x022ECEC0
cisco Systems, Inc.
What card was installed????
this is the card we used
NAME: "ESW Power Daughter Card", DESCR: "4-Port ESW Power Daughter Card"
PID: 800-IL-PM-2 , VID: V01 , SN: FOC14026UVM
it works properly on the model C881 SRST-K9 attached in picture .
however the model C881-K9 could not boot even with it  as mentioned in last post.
in pictures bellow you can see on the rare of the routers that C881 SRST-K9 have 2 power input  one 12v and the other for POE. while C881-K9 has only one .
my question is this model C881-K9 supports POE and if yes what it the card that we should purchase .
thanck you in advence
It looks like the router on the bottom do not support PoE, whether the daughter card is installed or not.
Yes i think so , but cisco tells it supports ,and you can see on ports F0an F1 that is writen POE.
Look at the front. The top has "PoE" LED slots. The one on the bottom doesn't. This means the one on the bottom doesn't support PoE.
I am afraid even the C881-K9 has the POE leds in the front .
