cisco 881g with 3g modem
zeuscyril
Level 4
Level 4
hi all,
i am trying to configure cisco 881g with 3g adapter , when i try to upgrade the adapter it is failed after that i am getting the following error and router keep on restarting . once i remove the adapter from router .it is working fine.
13:12:05 UTC Mon Aug 22 2011: Unexpected exception to CPU: vector 1100, PC = 0x
80556830, LR = 0x80556830
-Traceback= 0x80556830z 0x8054E1C4z 0x8054EFFCz 0x8054C9F8z 0x8054D244z 0x805536
E0z 0x804DFB88z 0x804C6AA0z
CPU Register Context:
MSR = 0x80009032  CR  = 0x88000022  CTR = 0x80350BD0  XER   = 0x00000000
R0  = 0x8054E1C4  R1  = 0x84E09460  R2  = 0xFFF9514C  R3    = 0xFB9DD23C
R4  = 0x83D40000  R5  = 0x00000004  R6  = 0x00000001  R7    = 0xFF400000
R8  = 0x2DFFFFFF  R9  = 0x85CD9B34  R10 = 0x00000000  R11   = 0x83140000
R12 = 0x48000022  R13 = 0xFFF96D54  R14 = 0x83160000  R15   = 0x83160000
R16 = 0x842A0000  R17 = 0x842A0000  R18 = 0x83140000  R19   = 0x84500000
R20 = 0x83160000  R21 = 0x00000003  R22 = 0x83D90000  R23   = 0x842A0000
R24 = 0x00000004  R25 = 0x85AD049C  R26 = 0x85300F84  R27   = 0x00000640
R28 = 0x86227D80  R29 = 0x00000006  R30 = 0x85CD9B1C  R31   = 0x00000000
Watchdog timeout exception
13:12:05 UTC Mon Aug 22 2011: Unexpected exception to CPU: vector 200, PC = 0x8
0C7A2E0, LR = 0x80C7A184
-Traceback= 0x80C7A2E0z 0x80C79834z 0x82034EE0z 0x80D23EC4z 0x80234848z 0x804DF7
38z 0x804DF7B8z 0x804DF898z 0x804E0F14z
MSR = 0x00081030  CR  = 0x24208044  CTR = 0x00000000  XER   = 0x00000000
R0  = 0x00000000  R1  = 0x844F8E3C  R2  = 0xFFF9514C  R3    = 0x00000000
R4  = 0x837454AF  R5  = 0x00000025  R6  = 0x00000000  R7    = 0x00000000
R8  = 0x00000000  R9  = 0x00000000  R10 = 0x00000039  R11   = 0x0000003C
R12 = 0x44008022  R13 = 0xFFF96D54  R14 = 0x00000020  R15   = 0xFFFFFFFF
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x83140000  R19   = 0xFFFFFFFF
R20 = 0x00000000  R21 = 0x00000001  R22 = 0x845533F0  R23   = 0x844F8F5C
R24 = 0x00000000  R25 = 0x83740000  R26 = 0x00000000  R27   = 0x00000000
R28 = 0x8318DB5C  R29 = 0x845533F0  R30 = 0x7FFFFFFF  R31   = 0x845533F0
Nested write_crashinfo call (2 times)
Writing crashinfo to flash:crashinfo_20110822-131206-UTC
=== Flushing messages (13:12:10 UTC Mon Aug 22 2011) ===
Buffered messages:
*Aug 22 13:11:50.615: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to
up
*Aug 22 13:12:05.659: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to
up
*Aug 22 13:12:05.659: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to
up
*Aug 22 13:12:05.659: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to
up
*Aug 22 13:12:05.691: %CISCO800-2-MODEM_INSERTED_DETECTED: Cellular0 modem is no
w INSERTED
*Aug 22 13:12:05.699: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "Et
hernet Msec Timer CFM", ipl= 0, pid= 84 -Traceback= 0x804C676Cz 0x82047E94z 0x80
123E6Cz 0x804DFB88z 0x804C6AA0z
*Aug 22 13:12:06.699: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value
= 0x1. -Process= "Ethernet Msec Timer CFM", ipl= 0, pid= 84 -Traceback= 0x804C67
A8z 0x82047E94z 0x80123E6Cz 0x804DFB88z 0x804C6AA0z
Queued messages:
*Aug 22 13:12:11.335: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console d
ebugging output.
*Mar  1 00:00:07.907: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module nam
e = c880-data Next reboot level = advipservices and License = advipservices
*Aug 22 13:11:32.051: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-ta
ble No such file or directory
*Aug 22 13:11:32.155: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Initialized
*Aug 22 13:11:32.299: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change
d to: Enabled
up
*Aug 22 13:11:51.355: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha
nged state to down
*Aug 22 13:11:51.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et4, changed state to down
*Aug 22 13:11:55.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chan
ged state to up
*Aug 22 13:11:56.147: %LINK-5-CHANGED: Interface FastEthernet4, changed state to
administratively down
*Aug 22 13:11:56.203: %LINK-5-CHANGED: Interface Cellular0, changed state to adm
inistratively down
*Aug 22 13:12:02.747: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 22 13:12:05.659: %LINK-5-CHANGED: Interface NVI0, changed state to administ
ratively down
up
up
up
*Aug 22 13:12:05.663: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(1)T2, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 07:32 by prod_rel_team
*Aug 22 13:12:05.663: %SNMP-5-COLDSTART: SNMP agent on host yourname is undergoi
ng a cold start
*Aug 22 13:12:05.683: %SSH-5-ENABLED: SSH 1.99 has been enabled
w INSERTED
*Aug 22 13:12:06.699: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Aug 22 13:12:06.699: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Aug 22 13:12:06.831: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chan
ged state to down
*Aug 22 13:12:06.831: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
et1, changed state to down
et2, changed state to down
et3, changed state to down
*Aug 22 13:12:09.955: %SYS-3-CPUHOG: Task is running for (2000)msecs, more than
(2000)msecs (2055/2055),process = Crash writer.
-Traceback= 0x80317BC4z 0x80317C64z 0x80317D50z 0x803183F4z 0x803185A0z 0x80318E
18z 0x80318FC4z 0x80319090z 0x80C71B0Cz 0x801D954Cz 0x801D3C38z 0x812719F0z 0x80
1DAA18z 0x812719F0z 0x819446A0z 0x81944758z
No warm reboot Storage
*** System received a SIGTRAP exception ***
signal= 0x5, code= 0x1100, context= 0x8431d0b0
Stack trace:
PC = 0x80556830, SP = 0x84e09478
Frame 00: SP = 0x84e09490    PC = 0x8054e1c4
Frame 01: SP = 0x84e094e8    PC = 0x8054effc
Frame 02: SP = 0x84e09508    PC = 0x8054c9f8
Frame 03: SP = 0x84e09540    PC = 0x8054d244
Frame 04: SP = 0x84e09598    PC = 0x805536e0
Frame 05: SP = 0x84e095a0    PC = 0x804dfb88
Frame 06: SP = 0x00000000    PC = 0x804c6aa0
CTR = 0x80350bd0  XER = 0x00000000  DAR = 0x00000000  DSISR = 0x00000000
DEC = 0x57cb4b62  TBU = 0x00000000  TBL = 0xa8348612  PVR   = 0x80830031
R0  = 0x8054e1c4  R1  = 0x84e09460  R2  = 0xfff9514c  R3    = 0xfb9dd23c
R4  = 0x83d40000  R5  = 0x00000004  R6  = 0x00000001  R7    = 0xff400000
R8  = 0x2dffffff  R9  = 0x85cd9b34  R10 = 0x00000000  R11   = 0x83140000
R12 = 0x48000022  R13 = 0xfff96d54  R14 = 0x83160000  R15   = 0x83160000
R16 = 0x842a0000  R17 = 0x842a0000  R18 = 0x83140000  R19   = 0x84500000
R20 = 0x83160000  R21 = 0x00000003  R22 = 0x83d90000  R23   = 0x842a0000
R24 = 0x00000004  R25 = 0x85ad049c  R26 = 0x85300f84  R27   = 0x00000640
R28 = 0x86227d80  R29 = 0x00000006  R30 = 0x85cd9b1c  R31   = 0x00000000
System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C880 platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
program load complete, entry point: 0x80020000, size: 0x1c4842c
Self decompressing the image : #################################################
#################################################### [OK]
Rozsa Illes
What is the type of the 3G modem? Is there a possibility to try the modem on another router/device whether it is working fine? Other modem(s) are working fine?
I had a quick look at the decodes but such a crash was only seen once so far (as I can see) and after the modem was replaced, the crash did not reoccur and it could not be analyzed further.
If the same modem is working fine on another device and other modems cause crashing as well, it would be good to consider an IOS upgrade to the newest software as a first step.
Cheers,
Rose
Rozsa Illes
Cheers,
Rose
