10-24-2012 05:17 AM - edited 03-04-2019 05:56 PM
for a costumer i have replaced there old small home router with this cisco 886.
i have configurd the atm interface, and the dialer interface.
i get a ip adres in the dialer from the isp , and i have internet connection.
everyting works except it is VERRY SLOW if i check the internet connection speed it is 0.49 Mbps down and 0.42 Mbps up (speedtest.net)
normaly i would get almost 4 Mbps download !
i have checkt with Belgacom (isp) the cabel and everyting is ok ! (with the previos router full speed internet! )
some portion of the config is included !
i tryed to put encapsulation on the atm aal5snap and aal5mux .... no diffrens...
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip access-group naar-binnen in
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname ######@SKYNET
ppp chap password 7 ############
10-24-2012 06:41 AM
found the file ... try to update it now....
10-24-2012 07:21 AM
I have preformd the vdsl upgrade : but the speed stays the same
output show controllers vdsl 0
Controller VDSL 0 is UP
Daemon Status: Up
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'ALCB'
Chip Vendor Specific: 0x0000 0x0000
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: FCZ163491FJ 886VA-S 15.2(3)
Serial Number Far:
Modem Version Near: 15.2(3)
Modem Version Far: 0x0000
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.992.1 (ADSL) Annex B
TC Mode: ATM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Trellis: ON ON
SRA: disabled disabled
SRA count: 0 0
Bit swap: enabled enabled
Bit swap count: 0 4
Line Attenuation: 0.0 dB 2.0 dB
Signal Attenuation: 0.0 dB 0.0 dB
Noise Margin: 22.4 dB 9.0 dB
Attainable Rate: 9380 kbits/s 848 kbits/s
Actual Power: 7.4 dBm 5.6 dBm
Total FECC: 0 0
Total ES: 0 0
Total SES: 0 0
Total LOSS: 0 0
Total UAS: 20 20
Total LPRS: 0 0
Total LOFS: 0 0
Total LOLS: 0 0
Full inits: 1
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Firmware Source File Name (version)
VDSL user config flash:vdsl.bin-A2pv6C035j (10)
Modem FW Version: 120306_1254-4.02L.03.B2pvC035j.d23j
Modem PHY Version: B2pvC035j.d23j
Vender Version: Bpv35j.23j 68
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 4640 0 512
SRA Previous Speed: 0 0 0 0
Total Cells: 0 2269329 0 0
User Cells: 0 90724 0 0
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Interleave (ms): 0.00 0.25 0.00 0.25
Actual INP: 0.00 0.00 0.00 0.00
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
router-ilc#
10-24-2012 08:01 AM
Can you post entire configuration.
10-24-2012 08:18 AM
Here you see the full config, the last ting i have change is de operation mode set to adsl1 (this is the one that i have here) but it stayes the same.....
Building configuration...
Current configuration : 5170 bytes
! Last configuration change at 16:46:15 CEST Wed Oct 24 2012 by administrator
version 15.2
service nagle
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname router-ilc
boot-start-marker
boot-end-marker
enable secret 5 ##############################
no aaa new-model
memory-size iomem 10
clock timezone CET 1 0
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 2:00
crypto pki trustpoint TP-self-signed-1448862176
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1448862176
revocation-check none
rsakeypair TP-self-signed-1448862176
crypto pki certificate chain TP-self-signed-1448862176
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31343438 38363231 3736301E 170D3132 30393139 31333130
31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34343838
36323137 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A395 DF58AEA2 4B66F159 273D1A07 09AA5C4B DBBAB439 D16FF476 EFCD3A0F
74029119 4284AA2F 7E05A2AA 5506E7B8 7D545AD8 A913F605 049BACF4 A9FF27B1
3A08EAF9 E5942A3D 64D8FEC8 E8D4963F 54F2C01D 6AE35952 A6105365 1EA4C6DC
CCBCA98C C4631176 9FF5F070 CDFDA04C FBEAA292 C63033CF DC6A4346 ABAB0DFA
1B3B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1484217F DEEAA03C 8C1A8D4C E41940F6 BBAFA56E 29301D06
03551D0E 04160414 84217FDE EAA03C8C 1A8D4CE4 1940F6BB AFA56E29 300D0609
2A864886 F70D0101 05050003 81810033 7EA26946 A12CEFC1 16455343 AB788827
B0AC810C F1A6DA47 3410C418 3203AD77 B630C536 0B096C85 FC6499FA 83BC90A6
02156170 032DD91C EC6A2528 1CC08D1F 07F6DC66 47353205 CF5E0A7A EDEA3B79
A2F215FE BA637698 E65FB49D 160608B4 D994D69C A2A91359 99B25DFF 9463FD2B
F4BE927F C50F3785 D731F33B E94754
quit
no ip source-route
no ip gratuitous-arps
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
no ip bootp server
ip name-server 195.238.2.21
ip name-server 195.238.2.22
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
license udi pid CISCO886VA-SEC-K9 sn FCZ163491FJ
username administrator privilege 15 password 7 ##############################
controller VDSL 0
operating mode adsl1
firmware filename flash:vdsl.bin-A2pv6C035j
interface Ethernet0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
pvc 8/35
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description vlan lan gebruikers
ip address 192.168.1.101 255.255.255.0
ip access-group naar-buiten in
ip nat inside
ip tcp adjust-mss 1452
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname ##############################
ppp chap password 7 ##############################
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.5 443 interface Dialer1 443
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended naar-binnen
permit tcp any any established
permit udp any eq domain any
permit icmp any any echo-reply
permit udp any eq ntp any
ip access-list extended naar-buiten
permit tcp 192.168.1.0 0.0.0.255 any eq www
permit tcp 192.168.1.0 0.0.0.255 any eq domain
permit tcp 192.168.1.0 0.0.0.255 any eq pop3
permit tcp 192.168.1.0 0.0.0.255 any eq smtp
permit tcp 192.168.1.0 0.0.0.255 any eq 443
permit udp 192.168.1.0 0.0.0.255 any eq domain
permit tcp 192.168.1.0 0.0.0.255 any eq 143
permit tcp 192.168.1.0 0.0.0.255 any eq 993
permit tcp 192.168.1.0 0.0.0.255 any eq 995
permit tcp 192.168.1.0 0.0.0.255 any eq 465
permit tcp 192.168.1.0 0.0.0.255 any eq 22
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
banner motd ^C
* This Router is manage by *
* Mahieu it services *
* Legal notice: unauthorized access to *
* this device is prohibited. *
* all activities on this system are *
* monitored and recorded for security *
*****************************************^C
line con 0
exec-timeout 15 0
login local
ip netmask-format decimal
stopbits 1
line aux 0
line vty 0 4
access-class 1 in
exec-timeout 15 0
login local
transport preferred ssh
transport input ssh
transport output ssh
ntp master
ntp server ntp.skynet.be
end
10-24-2012 08:23 AM
All seems fine to me. You can try removing ACL from interface, and downgrading to 15.1(4)M5.
10-24-2012 09:12 AM
i can try that tomorry, no i am not at location any more.
11-21-2012 07:09 AM
I have deleted the acl's from the dailer and lan interface and rebooted, but stil no progress, still 0,49 max download speed. ..
Normal i should have 4,5. ...
Could it be the atm settings? is there a way to lookup dig up de atm/dslam settings from my isp?
11-21-2012 07:22 AM
I have removed the mtu settings in de dailer interface ;.
No ip mtu
Sent from Cisco Technical Support Android App
11-21-2012 07:35 AM
No improvment jet. ...
11-21-2012 08:50 AM
Please post revised config again, as well "show int".
01-16-2013 04:08 AM
Hello, Sorry for te "very" late respons I was out voor medical reazons .
hier is the full config and show int !
Current configuration : 5401 bytes
! No configuration change since last restart
version 15.2
service nagle
no service pad
hostname router-ilc
boot-start-marker
boot-end-marker
enable secret 5 ******************************!
no aaa new-model
quit
no ip source-route
no ip bootp server
ip cef
no ipv6 cef
vpdn enable
vpdn-group pppoe
username administrator privilege 15 password 7 ****************!
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
pvc 8/35
encapsulation aal5snap
no ip address
no ip address
no ip address
no ip address
interface Vlan1
bandwidth inherit
ip nat inside
interface Dialer0
no ip address
no cdp enable
interface Dialer1
mtu 1492
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password 7 ****************
ppp direction callout
ppp ipcp header-compression ack
ppp ipcp dns request accept
ppp ipcp address accept
no cdp enable
ip http server
permit ip any any
permit ip any any
no cdp run
control-plane
banner motd ^C
line con 0
exec-timeout 15 0
login local
stopbits 1
line aux 0
line vty 0 4
access-class 1 in
exec-timeout 15 0
login local
transport input ssh
ntp master
end
01-16-2013 04:11 AM
ATM0 is up, line protocol is up
Hardware is MPC ATMSAR, address is 30f7.0dba.7a48 (bia 30f7.0dba.7a48)
MTU 1600 bytes, sub MTU 1600, BW 512 Kbit/sec, DLY 720 usec,
reliability 255/255, txload 6/255, rxload 255/255
Encapsulation ATM, loopback not set
Keepalive not supported
Encapsulation(s): AAL5
4 maximum active VCs, 1024 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 23:18:01, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 621
Queueing strategy: Per VC Queueing
5 minute input rate 900000 bits/sec, 144 packets/sec
5 minute output rate 13000 bits/sec, 12 packets/sec
8277715 packets input, 557607194 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
5668712 packets output, 993619991 bytes, 0 underruns
0 unknown protocol drops
BRI0 is administratively down, line protocol is down
Hardware is BRI with S/T interface
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
BRI0:1 is administratively down, line protocol is down
Hardware is BRI
BRI0:2 is administratively down, line protocol is down
router-ilc# show int
Hardware is BRI
Hardware is BRI
Dialer0 is up (spoofing), line protocol is up (spoofing)
Hardware is Unknown
MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
DTR is pulsed for 1 seconds on reset
Dialer1 is up, line protocol is up (spoofing)
Hardware is Unknown
Internet address is 87.64.238.140 255.255.255.255
MTU 1492 bytes, BW 56 Kbit/sec, DLY 20000 usec,
reliability 255/255, txload 36/255, rxload 255/255
Encapsulation PPP, LCP Closed, loopback not set
Interface is bound to Vi1
Last clearing of "show interface" counters 4w4d
30 second input rate 927000 bits/sec, 142 packets/sec
30 second output rate 8000 bits/sec, 7 packets/sec
8002276 packets input, 279530625 bytes
5669638 packets output, 820975655 bytes
Bound to:
Virtual-Access1 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1492 bytes, BW 512 Kbit/sec, DLY 20000 usec,
reliability 255/255, txload 3/255, rxload 255/255
Encapsulation PPP, LCP Open
Open: IPCP
PPPoE vaccess, cloned from Dialer1
Vaccess status 0x44, loopback not set
Interface is bound to Di1 (Encapsulation PPP)
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 23:18:59
5 minute input rate 873000 bits/sec, 142 packets/sec
5 minute output rate 7000 bits/sec, 10 packets/sec
746270 packets input, 759341025 bytes, 0 no buffer
343840 packets output, 46513958 bytes, 0 underruns
FastEthernet0 is up, line protocol is up
Hardware is Fast Ethernet, address is 30f7.0dba.7a48 (bia 30f7.0dba.7a48)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Full-duplex, 100Mb/s
5 minute output rate 46000 bits/sec, 2 packets/sec
2926011 packets input, 542908367 bytes, 0 no buffer
Received 17113 broadcasts (66605 multicasts)
0 watchdog, 0 multicast, 0 pause input
7712694 packets output, 271139827 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
3 lost carrier, 0 no carrier, 0 pause output
FastEthernet1 is up, line protocol is up
Hardware is Fast Ethernet, address is 30f7.0dba.7a49 (bia 30f7.0dba.7a49)
5 minute output rate 1000 bits/sec, 2 packets/sec
1448850 packets input, 196148987 bytes, 0 no buffer
Received 5490 broadcasts (4216 multicasts)
5849083 packets output, 2921351045 bytes, 0 underruns
44 lost carrier, 0 no carrier, 0 pause output
FastEthernet2 is up, line protocol is up
Hardware is Fast Ethernet, address is 30f7.0dba.7a4a (bia 30f7.0dba.7a4a)
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 2000 bits/sec, 1 packets/sec
4144732 packets input, 1615523164 bytes, 0 no buffer
Received 2251335 broadcasts (463549 multicasts)
2868810 packets output, 1149918918 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
FastEthernet3 is up, line protocol is up
Hardware is Fast Ethernet, address is 30f7.0dba.7a4b (bia 30f7.0dba.7a4b)
reliability 255/255, txload 2/255, rxload 1/255
5 minute input rate 5000 bits/sec, 8 packets/sec
5 minute output rate 845000 bits/sec, 138 packets/sec
1308842 packets input, 336443492 bytes, 0 no buffer
Received 8588 broadcasts (17356 multicasts)
4036335 packets output, 2679753915 bytes, 0 underruns
115 lost carrier, 0 no carrier, 0 pause output
NVI0 is administratively down, line protocol is down
Hardware is NVI
MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Encapsulation UNKNOWN, loopback not set
reliability 255/255, txload 1/255, rxload 255/255
Open: IPCP
Last clearing of "show interface" counters 23:20:06
5 minute input rate 888000 bits/sec, 141 packets/sec
5 minute output rate 4000 bits/sec, 9 packets/sec
755709 packets input, 767068207 bytes, 0 no buffer
344561 packets output, 46589179 bytes, 0 underruns
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 30f7.0dba.7a48 (bia 30f7.0dba.7a48)
Description: vlan lan gebruikers
Internet address is 192.168.1.101 255.255.255.0
5 minute input rate 7000 bits/sec, 12 packets/sec
5 minute output rate 904000 bits/sec, 142 packets/sec
7708115 packets input, 1104291195 bytes, 0 no buffer
Received 2279719 broadcasts (162 IP multicasts)
0 runts, 0 giants, 20 throttles
7949478 packets output, 375347285 bytes, 0 underruns
0 output errors, 1 interface resets
72303 unknown protocol drops
01-16-2013 04:11 AM
show ip int brief :
ATM0 unassigned YES NVRAM up up
BRI0 unassigned YES NVRAM administratively down down
BRI0:1 unassigned YES unset administratively down down
BRI0:2 unassigned YES unset administratively down down
Dialer0 unassigned YES unset up up
Dialer1 87.64.238.140 YES IPCP up up
Ethernet0 unassigned YES NVRAM administratively down down
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset up up
FastEthernet3 unassigned YES unset up up
NVI0 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Vlan1 192.168.1.101 YES NVRAM up up
01-16-2013 04:19 AM
Interface ATM0:
AAL enabled: AAL5,, Maximum VCs: 4, Current VCCs: 1
VCIs per VPI: 1024,
Max. Datagram Size: 1658
PLIM Type: ADSL - 512Kbps Upstream, DMT, TX clocking: LINE
133785 input, 27 output, 8212447 IN fast, 5279512 OUT fast
Avail bw = 512
Config. is ACTIVE
01-16-2013 04:21 AM
Daemon Status: Up
Serial Number Far:
DSL Config Mode: ADSL
TC Mode: ATM
Trellis: ON ON
SRA count: 0 0
Bit swap count: 0 4
Line Attenuation: 0.0 dB 1.0 dB
Noise Margin: 19.7 dB 9.0 dB
Attainable Rate: 8672 kbits/s 848 kbits/s
Actual Power: 7.3 dBm 5.6 dBm
Total FECC: 0 0
Total ES: 1 0
Total SES: 0 0
Total LOSS: 0 0
Total UAS: 34 34
Total LPRS: 0 0
Total LOFS: 0 0
Total LOLS: 0 0
Full inits: 1
Short inits: 0
Total Cells: 0 1119761094 0 0
User Cells: 0 195561778 0 0
CRC Errors: 0 1 0 0
Header Errors: 0 1 0 0
