344
memmas nanashi
Beginner
Cisco 886 strange route-map problem
I have a cisco 886VA with c880data-universalk9-mz.154-3.M9.bin and acrtivated advipservices license.
I have a multipoint VPN using GRE.
My problem is that although ISKMP in ON
c886#sh control-plane host open-ports | i ISAKMP
 udp                      *:4500                         *:0                   ISAKMP   LISTEN
 udp                       *:500                         *:0                   ISAKMP   LISTEN
if I nmap the ports from outside I get
PORT     STATE  SERVICE
500/udp  closed isakmp
4500/udp closed sae-urn
Bellow is the problem I'm facing..
ip nat inside source route-map NAT interface Dialer46 overload
ip nat inside source static tcp <asterisk-server> 22 <router's statis IP> 22 extendable
ip nat inside source static <asterisk-server> <router's statis IP> route-map SIP
route-map SIP permit 10
 match ip address ASTERISK
route-map NAT permit 10
 match ip address PAT XVPN
 match interface Dialer46
ip access-list extended ASTERISK
 permit udp host <asterisk-server> any range 15000 18000
 permit udp host <asterisk-server> any range 40000 50087
I narrow down the problem to this line
when I apply it I loose VPN and I can verify that instead of forward only the udp range on ASTERISK access-list it forwards all ports, including 500,4500.
I run on asterisk a netcat listener on udp port 500 and nmap responded.
Am I doing something wrong or this is a bug?
0 REPLIES 0
