Highlighted
Beginner
Cisco 887 3G
           I'm trying to setup Cisco 887g-w router with 3G GSM SIM card. We got a data sim card from telco with a static IP address. Below is the some outputs. The cellular interface keeps flapping, but am not able to ping at all to any public IP address and it's not connected. Can anyone please help me on this?
International Mobile Subscriber Identity (IMSI) = 525016180934095
International Mobile Equipment Identity (IMEI) = 353223040059355
Integrated Circuit Card ID (ICCID) = 8965011104140220958
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) = D9E260018221004
Modem Status = Online
Current Modem Temperature = 30 deg C, State = Normal
PRI SKU ID = 9993559, SKU Rev. = 1.2
Profile Information
Profile password Encryption level: 7
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = <xxxxx>
Authentication = CHAP
Username: <xxxxx>, Password: <xxxxxx>
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Service option not subscribed
Profile 2, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = Requested service option not su
bscribed
Current Service = Combined
Packet Service = UMTS/WCDMA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = SGP, Network = SingTel
Mobile Country Code (MCC) = 525
Mobile Network Code (MNC) = 1
Location Area Code (LAC) = 305
Routing Area Code (RAC) = 1
Cell ID = 33443
Primary Scrambling Code = 304
PLMN Selection = Automatic
Registered PLMN =  , Abbreviated =
Service Provider = SingTel
Radio Information
Radio power mode = ON
Current Band = WCDMA 2100, Channel Number = 10664
Current RSSI(RSCP) = -83 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
        Primary Scrambling Code = 0x130
        RSCP = -86 dBm, ECIO = -8 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Agility3G#
000212: *Jun 23 12:25:29.695 PCTime: %LINK-3-UPDOWN: Interface Cellular0, change
d state to down
000213: *Jun 23 12:25:41.783 PCTime: %LINK-3-UPDOWN: Interface Cellular0, change
d state to up
000214: *Jun 23 12:25:41.783 PCTime: %DIALER-6-BIND: Interface Ce0 bound to prof
ile Di0
000215: *Jun 23 12:25:42.823 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Inter
face Cellular0, changed state to up
chat-script gsm "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
interface Cellular0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode interactive
interface Dialer0
ip address 202.x.x.x 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
ppp chap hostname <xxxxx>
ppp chap password 7 <xxxx>
ppp ipcp dns request
no cdp enable
ip route 0.0.0.0 0.0.0.0 Dialer0
line 3
script dialer gsm
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
thanks
4 REPLIES 4
Highlighted
Hall of Fame Master
Which exact IOS are you using ?
Highlighted
Hello Paolo,
    As requested below info.
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(1)T2, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 07:32 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
System image file is "flash:c880data-universalk9-mz.151-1.T2.bin"
Last reload type: Normal Reload
Cisco 887G (MPC8300) processor (revision 1.0) with 472064K/52224K bytes of memory.
Processor board ID FHK145373AD
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 ATM interface
3 terminal lines
1 Virtual Private Network (VPN) Module
1 Cellular interface
1 cisco Embedded AP (s)
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO887GW-GN-E-K9    FHK145373AD
License Information for 'c880-data'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
thanks
Highlighted
Try 15.0(1)M6
Highlighted
The issue was wrong APN provider by telco. Now it's working fine. Thanks for your support.
