Cisco 887 Need help
I have configured a Cisco 887, I can connect to the internet through the router, but as soon as i connect PC i can't connect. i have checked that my dialer 0 comes up and i get an ip address. but i cant ping anything on the Internet.
here is the current config.
Building configuration...
Current configuration : 2088 bytes
! Last configuration change at 04:18:44 UTC Tue Mar 10 2015
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn ****************
controller VDSL 0
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 description connection to telkom
 no ip address
 no atm ilmi-keepalive
interface ATM0.35 point-to-point
 description telkom adsl
 pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
 switchport mode trunk
 no ip address
interface FastEthernet1
 no ip address
 shutdown
interface FastEthernet2
 no ip address
 shutdown
interface FastEthernet3
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.0.0.254 255.255.255.0
interface Vlan20
 ip address 10.0.1.254 255.255.255.0
interface Vlan30
 ip address 10.0.2.254 255.255.255.0
interface Vlan40
 ip address 10.0.3.254 255.255.255.0
interface Dialer0
 description To Telkom ADSL 1
 ip address negotiated
 no ip redirects
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname **********************
 ppp chap password 0 *****************
 ppp pap sent-username ***************** password 0 *******************
 ppp ipcp dns request accept
 ppp ipcp route default
 ppp ipcp address accept
 no cdp enable
ip default-gateway 10.0.0.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map DIAL0 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list standard NAT
 permit 10.0.0.0 0.0.0.255
route-map DIAL0 permit 10
 match ip address NAT
 match interface Dialer0
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
Leo Laohoo
If the PC is connected to F0?
Interface F0 is associated to VLAN 1.
No, its not that i never put nating on the vlans and my route was wrong.
its working now, thanks for the help
