Cisco 887VA-W-E-K9 AP reloading continuously
Hamish Marson
I have an issue. I've got a brand new C887VA-W-E-K9 that is up and running on a BT VDSL connection. That side of it is fine... But the integrated AP module on it keeps reloading... I can be on the AP console reading the config via 'sh run' and suddenly it'll be loading the OS again... There's no errors logged, no errors on the console or anything... (I also have yet to get the radio working, it starte dbefore I'd finished the config).
It doesn't seem to be anything I'm doing as if I just leave the console, it'll just sit there... reloading every few minutes... (Although sometimes it seems to stay up for longer).
The console just looks like this. WHich is taken from listing the running config and while sitting at the --more-- prompt... Bang...
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging 192.168.254.254
bridge 1 route ip
line con 0
line vty 0 4
login local
end
--More--
IOS Bootloader - Starting system.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 40:55:39:c7:53:7e
Initializing Ethernet interface
Ethernet Interface initialization OK.
Unable to get our ip address: no "IP_ADDR" variable set
The system has encountered an error initializing the
TFTP file system. The system is ignoring the error and
continuing to boot. If you abort the boot process,
the following commands will set IP_ADDR, DEFAULT_ROUTER
and NETMASK environment variables, initialize the tftp
system, and load the operating system software:
    set IP_ADDR
    set DEFAULT_ROUTER
    set NETMASK
    tftp_init
    boot
TFTP initialization is done.
Boot system image.
Loading "flash:/ap802-k9w7-mx.124-25d.JAX/ap802-k9w7-mx.124-25d.JAX"...######################################################################################################################################################################################################################################
File "flash:/ap802-k9w7-mx.124-25d.JAX/ap802-k9w7-mx.124-25d.JAX" uncompressed and installed, entry point: 0x18003000
executing...
           Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, AP802 Software (AP802-K9W7-M), Version 12.4(25d)JAX, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 25-Jul-11 22:10 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
...done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present 8363 8000 A0000000 0 A0010000 4C
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AP802GN-E-K9         (revision A0) with 98304K/32768K bytes of memory.
Processor board ID ************
Last reset from power-on
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 40:55:39:C7:53:7E
Part Number                          : 74-7519-02
PCA Assembly Number                  : 800-34495-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC154913KN
Top Assembly Part Number             : 800-34364-01
Top Assembly Serial Number           : *********
Top Revision Number                  : A0
Product/Model Number                 : AP802GN-E-K9
Selected country United Kingdom (UK)
Press RETURN to get started!
H
6 Replies 6
Leo Laohoo
In the WAP, can you please post the output to the command "dir"?
ap-887vaw#dir
Directory of flash:/
    1  -rw-        1469  Jan 28 2012 23:09:08 +00:00  config.txt
    2  -rw-         126  Jan 28 2012 23:10:02 +00:00  env_vars
    3  -rw-     6645760  Jan 12 2012 12:08:56 +00:00  ap802-k9w7-tar.124-25d.JAX.tar
    4  -rw-     3256320  Jan 12 2012 12:09:18 +00:00  ap802-rcvk9w8-tar.124-23c.JA2.tar
    5  drw-           0  Jan 12 2012 12:09:42 +00:00  ap802-k9w7-mx.124-25d.JAX
  155  -rw-        5374  Jan 27 2012 11:42:28 +00:00  event.log
  156  drw-           0  Jan 12 2012 12:12:10 +00:00  ap802-rcvk9w8-mx.124-23c.JA2
  162  -rw-           5  Jan 28 2012 23:09:08 +00:00  private-config
  163  -rw-        1048  Jan 28 2012 23:09:10 +00:00  private-multiple-fs
48877568 bytes total (28725248 bytes free)
ap-887vaw#sh ver
ROM: Bootstrap program is AP802 boot loader
BOOTLDR: AP802 Boot Loader (AP802-BOOT-M), Version 12.4 [vnanduri-MC2_WEEKLY_10242011 100]
ap-887vaw uptime is 8 minutes
System returned to ROM by power loss
System image file is "flash:/ap802-k9w7-mx.124-25d.JAX/ap802-k9w7-mx.124-25d.JAX"
--More--
H
Did you end up resolving this issue as im having the same problem. The WAP code (12.x) is current (last updated mid last year)..
Im thinking it could be part of the 'service-module wlan-ap 0  heartbeat-reset' .. but im still researching
Can you post the output to the following commands please:
1.  dir;
2.  sh version;
3.  sh log;
    2  -rw-        1987  Mar 28 2012 15:24:10 +10:30  config.txt
  162  -rw-         395  Mar 28 2012 15:29:34 +10:30  env_vars
    3  -rw-     6645760   Mar 9 2012 06:26:48 +10:30  ap802-k9w7-tar.124-25d.JAX.tar
    4  -rw-     3256320   Mar 9 2012 06:27:04 +10:30  ap802-rcvk9w8-tar.124-23c.JA2.tar
    5  drw-           0   Mar 9 2012 06:27:28 +10:30  ap802-k9w7-mx.124-25d.JAX
  155  drw-           0   Mar 9 2012 06:29:58 +10:30  ap802-rcvk9w8-mx.124-23c.JA2
    1  -rw-        3587  Mar 28 2012 15:24:10 +10:30  private-config
  161  -rw-        1048  Mar 28 2012 15:24:12 +10:30  private-multiple-fs
48877568 bytes total (28737536 bytes free)
LAB887VA-W_AP#sh version
LAB887VA-W_AP uptime is 2 minutes
export@cisco.com.
cisco AP802GN-A-K9         (revision A0) with 98304K/32768K bytes of memory.
Processor board ID FTX161084JW
Last reset from power loss
1 802.11 Radio(s)
Base ethernet MAC Address: 40:55:39:C8:00:6E
PCB Serial Number                    : FOC160578HY
Top Assembly Serial Number           : FTX161084JW
Product/Model Number                 : AP802GN-A-K9
Configuration register is 0xF
*Mar  1 00:00:02.843: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:05.639: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:05.747: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:07.235: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:07 UTC Fri Mar 1 2002 to 09:30:07 ACST Fri Mar 1 2002, configured from console by console.
*Mar  1 00:00:07.235: %SYS-6-CLOCKUPDATE: System clock has been updated from 09:30:07 ACST Fri Mar 1 2002 to 10:30:07 ACST Fri Mar 1 2002, configured from console by console.
*Mar  1 00:00:08.939: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:08.943: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:09.579: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:19:21.031: %SYS-5-RESTART: System restarted --
*Mar  1 00:19:21.031: %SNMP-5-COLDSTART: SNMP agent on host LAB887VA-W_AP is undergoing a cold start
*Mar  1 00:19:21.351: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Mar  1 00:19:21.359: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning frequencies for 24 seconds
*Mar  1 00:19:21.391: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:19:21.399: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning frequencies for 16 seconds
*Mar  1 00:19:22.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:19:38.063: %DOT11-6-FREQ_USED: Interface Dot11Radio0, frequency 2422 selected
*Mar  1 00:19:38.067: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:19:39.067: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Hmmmm ... That's bizarre.
Your router is brand new, isn't it?  You got it about 5 days ago?
