02-04-2014 09:29 AM - edited 03-04-2019 10:15 PM
Hi guys,
Can someone please post a template for the above router, I am trying to get it connected to my VDSL2 service.
ATM Settings
VPI 0 VCI 38
Encapsulation
PPPoE
Authentication
CHAP
Primary DNS
212.30.8.70
Secondary DNS
212.30.16.251
Protocol
PPPoE
Modulation Type
ITU-T 993.2
Cheers
02-04-2014 01:16 PM
I can provide part of it but not the PPPoE. This is for Ethernet access.
controller VDSL 0
firmware filename flash:VA_A_35l_B_35l_23j.bin
interface ATM0
no ip address
no ip redirects
no ip proxy-arp
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address 75.x.y.z 255.255.255.252
no ip redirects
no ip proxy-arp
ip virtual-reassembly in
atm route-bridged ip
pvc 0/35
encapsulation aal5snap
ip route 0.0.0.0 0.0.0.0 75.x.y.v
02-06-2014 05:17 AM
Refer to following doc for config
-Vishesh
02-07-2014 12:41 AM
What information has your ISP provided you with regarding configuring VDSL2? For example, they may require VLAN tagging.
This should help get you started:
In particular, note that you do not use ATM settings, these are for configuring ADSL. In fact the ATM interface should be shutdown and the configuration is done via the VDSL controller's Ethernet0 interface.
02-15-2014 04:10 AM
Hi guys,
There's no VLAN tagging going on here. I've had a look at the documents, it's not making a lot of sense to be honest. Any chance you could kindly post a templte for me?
Thank you
02-15-2014 10:44 PM
There's a config in this posting:
https://supportforums.cisco.com/message/4083135#4083135
(As you apparently don't need VLAN tagging the subinterface on E0 in this posting is not a necessary step).
08-31-2020 09:01 PM
Hi Xividar I have an 887VA connected to Telstra FTTN which uses VDSL2, this may be of use to you: hostname 887VA ! clock timezone AWST 8 ! no ip source-route ip cef ! multilink bundle-name authenticated ! username admin privilege 15 secret SECRET ! enable secret SECRET enable password PASSWORD ! archive log config hidekeys exit exit ! interface ATM0 shut exit ! interface Dialer0 shut exit ! interface Ethernet0 description TELSTRA CONNECTION ip address negotiated ip access-group 121 in no ip redirects no ip unreachables no ip proxy-arp ip mtu 1492 ip virtual-reassembly in encapsulation ppp ip tcp adjust-mss 1452 no cdp enable ! interface Vlan1 description DMZ ip address 203.30.44.62 255.255.255.128 no ip redirects no ip unreachables no ip proxy-arp ip virtual-reassembly in ip tcp adjust-mss 1452 hold-queue 100 out ! interface FastEthernet0 no shut exit interface FastEthernet1 no shut exit interface FastEthernet2 no shut exit interface FastEthernet3 no shut ! no ip http server ip http access-class 2 ip http authentication local ip http secure-server ! ip route 0.0.0.0 0.0.0.0 Ethernet0 ip ssh time-out 60 ip ssh authentication-retries 2 ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr ! snmp-server community LO_snmp RO access-list 121 permit ip any any ! banner login ^C Have a nice day ;-) ^C ! line con 0 no modem enable transport output telnet line aux 0 transport output telnet line vty 0 4 exec-timeout 30 0 password PASSWORD transport input telnet ssh ! no cdp run ! ntp clock-period 17180370 ntp server 129.143.2.23 ! webvpn cef ! line vty 0 4 access-class 1 in no exec-timeout privilege level 15 login local transport preferred ssh transport input ssh controller vdsl 0 lldp run
