09-21-2012 10:11 AM - edited 03-04-2019 05:38 PM
Unable to Edit or Add NAT using CCP 2.6???
09-24-2012 06:19 PM
hi stephen,
could you post what error do you get in CCP? i also have version 2.6 installed and maybe i can help walkthrough with you.
are you able to edit or add NAT via CLI?
09-25-2012 04:36 AM
Thank you for replying. The problem has been solved. The new ver. of Java 7 was causing the problem. Removed Java 7 and re-installed java 6 and the CCP work correctly.
09-25-2012 04:52 AM
Ah yes that can be troublesome sometimes. I've also dowgraded mine when I start using CCP. Glad you've managed to resolve it.
