Cisco ASR 1000 as voice gateway, WAN edge router, and internet router
lieuyong10
Hi all, just wonder if it is possible to use Cisco ASR 1000 series router to function as a voice gateway (connected via 2 E1 links to PSTN), WAN edge router (connected to MPLS VPN WAN), and internet router (connected to Internet) ?
Collin Clark
You can. Here's a quote from the ASR1000 datasheet-
Next-generation voice and multimedia example: Cisco Unified Border Element (SP Edition):
The SBC application (named Cisco Unified Border Element [SP Edition]) performs the voice and video gateway functions simultaneously with regular IP data services. No appliance or additional service blade is required. The control protocols and media protocols work transparently within a complex voice architecture.
Hope it helps
Collin Clark
Hope it helps
Hi Collin,
Thanks a lot!
Is there any disadvantage when using Cisco ASR as voice gateway, WAN edge router, and internet router when compared with traditional deployment such as 1 Cisco ISR router for voice gateway, and 1 Cisco ISR router for wan edge and internet?
I don't think there are any disadvantages. Providing all three services on a single router is nice. You can add as much redundancy as you like, you only have a single platform to manage, etc. The ASR has a ton of power so that shouldn't be a concern. IOS XE has some minor differences from IOS, but nothing too bad.
