04-24-2019 09:37 PM
I need help with buying the above model and all the necessities to host 4 WAN links - 3 x 100Mbps WAN and 1 x 1Gbps WAN
Data sheet shows built in Gigabit ethernet ports - 6 gigabit ethernet SFP pluggable ports. So I don't have to buy any other modules ? I believe the default IP based Cisco IOS XE is ok for now
Any help will be really appreciated
04-24-2019 11:50 PM
04-25-2019 11:42 AM
Thank you Leo. Those WAN links are presented as UTP from our providers CPE
04-25-2019 02:29 PM
04-25-2019 02:41 PM
So 6 x GLC-TE. How about the 2 x 10GB ports. They come with the router ? I might in future use this as a backup router to host our VPN tunnel to the HQ which is currently host on another device. The default IOS can handle IPSec over GRE tunnels ?
04-25-2019 11:30 PM
04-26-2019 03:26 AM
Thanks @Leo Laohoo
Please confirm, so in total this is what I have to procure:
04-30-2019 12:52 PM
Ive receive a quotation from a local vendor and its out of our budget. Is there another WAN router model that have the capacity to at least do the following
04-30-2019 01:54 PM
04-30-2019 03:11 PM
Much appreciated @shaps
On another note we've got two Cisco Nexus N9K-C9372TX , performing the following roles:
So probably I can just configure at least 4 ports as router port and use that instead of buying extra devices ? Will this be ok concerning the above roles ? Processor and memory usage not above 10% considering the above roles for the two boxes
