02-07-2018 10:45 PM - edited 03-05-2019 09:53 AM
Hi All,
Is there any command for snmp to send traps when temperature raise or fall from defined threshold on ASR100 series router? or Is this something happen by default by enabling 'snmp-server enable traps alarms' command?
Godwin. S
Solved! Go to Solution.
02-09-2018 07:27 AM
hello,
you should have the following Mibs enabled in order to access hardware monitoring info via SNMP:
The old CISCO-ENVMON-MIB has been replaced by these Mibs for ASR1000 platform.
02-09-2018 07:27 AM
hello,
