02-05-2024 04:47 PM
Good evening, I installed a C-NIM-4X card into a Cisco C8300-2N2S-6T router, when I looked at the status is said "booting" and I can't access it.
Can someone help with getting this card becoming active please?
02-06-2024 12:39 AM
- Attach a console to the router and scrutinize the complete boot process ?
- https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/catalyst-8000-series-gigabit-ethernet-lan-wan-modules-ds.html , look at Table 4 and report back
M.
02-06-2024 01:53 AM
Thank you Marce 1000, I tried another module out of the box, and even on a different router, and they both produced the same result.
02-06-2024 02:22 AM - edited 02-06-2024 02:57 AM
- Take care as other posted , to install the minimum IOS version required , 17.11.1
Ref : https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/catalyst-8000-series-gigabit-ethernet-lan-wan-modules-ds.html Table 1
Min. required IOS Version |
17.11.1 |
17.11.1 |
M.
02-06-2024 01:32 AM
Minimum required IOS version: 17.11.1
