Cisco Catalyst 3550 Optical L3 switch rate limiting
shivathapa
Hi All,
I have cisco cisco 3550 catalyst switch where rate-limit commands is not recognized.So I need to rate-limit to certain port for 11Mbps bandwidth.I tried but couldn't so ,If anyone has some idea??
Currelty client is hitting 13mbps where it should be only 11mbps..
HI,
I already tried police command for restricting but could not for 11mbps link.
class-map match-any websurfer-out
match ip dscp default
class-map match-any websurfer-in
match access-group 101
policy-map 11mb-websurfer-in
class websurfer-in
police 11000000 512750 exceed-action drop
policy-map 11mb-websurfer-out
class websurfer-out
this is what I have configured.
Its not working,
Plz help me out
Did you check your classification is working correctly ?
How is the trust state of your ingress interface. If they are in untrusted mode, you need to match DSCP 0 instead of default.
Here is an example:
mls qos
class-map match-all data1
match access-group 145
class-map match-all data2
match ip dscp 0
policy-map EGRESS
class data2
policy-map INGRESS
class data1
interface FastEthernet0/x
service-policy input INGRESS
service-policy output EGRESS
access-list 145 permit ip any any
Laurent.
Is it necessary to match ip dscp 0?? what will this command do ? and what meas trust state or untrusted state?
Thanx in advance.
