Cisco Content Filtering
d.junaedi
Hi All,
Need help with setting up Web Filtering on Cisco881 sec K9 router using CCP.
At the moment every user on the domain got blocked by the rule that i set up on the Web Filter (just using the wizard and choose default category). What i want is to separate users so that specific user can have full access while other user get filtered by the category.
And Yes I want to configure this using CCP.
Thanks.
d.junaedi
No one can help me here?
Is this possible or not?
Most people here rarely if ever use CCP to configure devices.
Can you post the show run output to see which feature in IOS this is referring to, if it is using NBAR and url filtering with MQC approach  then yes this can be done but on an IP address basis or even a MAC address basis but I have to verify if I'm correct concerning the MAC filtering.
Regards.
Alain
Running Config as follow
Building configuration...
Current configuration : 18052 bytes
! Last configuration change at 11:26:14 PCTime Tue Nov 8 2011 by abi
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco881
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$W82K$v3PYL6rJccXNdRk5FLDfE.
no aaa new-model
memory-size iomem 10
clock timezone PCTime 7
crypto pki trustpoint TP-self-signed-877078919
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-877078919
revocation-check none
rsakeypair TP-self-signed-877078919
crypto pki trustpoint Equifax_Secure_CA
crypto pki trustpoint NetworkSolutions_CA
crypto pki trustpoint trps1_server
crypto pki certificate chain TP-self-signed-877078919
certificate self-signed 01
  30820246 308201AF A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 38373730 37383931 39301E17 0D313131 31303330 39333530
  335A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3837 37303738
  39313930 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  AC49B79B 032F803C 4A4655B1 03CDF8E2 35552118 99FD6B71 92D38693 42C3900F
  2CCABDA6 081EA67F F4CEBC64 CFF0B6EA 92288021 8FB4C49D FEA21672 EBE45AB3
  28D35F8C A1791216 86C0EA9D E86CA234 39A379BE 25B074A1 679133E1 35C9AE80
  C5867CBD 88E3F74E EADB6C83 F81918F1 39EB1113 7001F8AC 2A6F1931 87E359FF
  02030100 01A37030 6E300F06 03551D13 0101FF04 05300301 01FF301B 0603551D
  11041430 12821063 6973636F 3838312E 6162692E 636F6D30 1F060355 1D230418
  30168014 D01194C8 B0CEC132 D759BB38 AA876854 F2C15576 301D0603 551D0E04
  160414D0 1194C8B0 CEC132D7 59BB38AA 876854F2 C1557630 0D06092A 864886F7
  0D010104 05000381 81006CE3 9535330C 12404E5E D4D44DAE BD75FC35 FD02B611
  5F16E1F5 C51E9E9A 7BA6F145 586A99A1 2B195F2F 7C4400CB 2BE66BC2 9C97182F
  146F5C9C D602AFB0 B577537D 0631BAC9 F5522492 13D07E16 8ACFBCBF BCDA7923
  3872EDD4 2AE9E291 31297983 52A216DD DDFA2E4A 43FC34A4 FF2202C0 2F33C387
  4AFCE0C5 8FEA07E8 B3EB
      quit
crypto pki certificate chain Equifax_Secure_CA
certificate ca 35DEF4CF
  30820320 30820289 A0030201 02020435 DEF4CF30 0D06092A 864886F7 0D010105
  0500304E 310B3009 06035504 06130255 53311030 0E060355 040A1307 45717569
  66617831 2D302B06 0355040B 13244571 75696661 78205365 63757265 20436572
  74696669 63617465 20417574 686F7269 7479301E 170D3938 30383232 31363431
  35315A17 0D313830 38323231 36343135 315A304E 310B3009 06035504 06130255
  53311030 0E060355 040A1307 45717569 66617831 2D302B06 0355040B 13244571
  75696661 78205365 63757265 20436572 74696669 63617465 20417574 686F7269
  74793081 9F300D06 092A8648 86F70D01 01010500 03818D00 30818902 818100C1
  5DB15867 0862EEA0 9A2D1F08 6D911468 980A1EFE DA046F13 846221C3 D17CCE9F
  05E0B801 F04E34EC E28A9504 64ACF16B 535F05B3 CB6780BF 42028EFE DD0109EC
  E100144F FCFBF00C DD43BA5B 2BE11F80 70991557 9316F10F 976AB7C2 68231CCC
  4D5930AC 511E3BAF 2BD6EE63 457BC5D9 5F50D2E3 500F3A88 E7BF14FD E0C7B902
  03010001 A3820109 30820105 30700603 551D1F04 69306730 65A063A0 61A45F30
  5D310B30 09060355 04061302 55533110 300E0603 55040A13 07457175 69666178
  312D302B 06035504 0B132445 71756966 61782053 65637572 65204365 72746966
  69636174 65204175 74686F72 69747931 0D300B06 03550403 13044352 4C31301A
  0603551D 10041330 11810F32 30313830 38323231 36343135 315A300B 0603551D
  0F040403 02010630 1F060355 1D230418 30168014 48E668F9 2BD2B295 D747D823
  20104F33 98909FD4 301D0603 551D0E04 16041448 E668F92B D2B295D7 47D82320
  104F3398 909FD430 0C060355 1D130405 30030101 FF301A06 092A8648 86F67D07
  4100040D 300B1B05 56332E30 63030206 C0300D06 092A8648 86F70D01 01050500
  03818100 58CE29EA FCF7DEB5 CE02B917 B585D1B9 E3E095CC 25310D00 A6926E7F
  B692639E 5095D19A 6FE411DE 63856E98 EEA8FF5A C8D355B2 667157DE C021EB3D
  2AA72349 01048642 7BFCEE7F A21652B5 6767D340 DB3B2658 B228773D AE147761
  D6FA2A66 27A00DFA A7735CEA 70F19421 65445FFA FCEF2968 A9A28779 EF79EF4F AC077738
      quit
crypto pki certificate chain NetworkSolutions_CA
certificate ca 10E776E8A65A6E377E050306D43C25EA
  308204A6 3082038E A0030201 02021010 E776E8A6 5A6E377E 050306D4 3C25EA30
  0D06092A 864886F7 0D010105 05003081 97310B30 09060355 04061302 5553310B
  30090603 55040813 02555431 17301506 03550407 130E5361 6C74204C 616B6520
  43697479 311E301C 06035504 0A131554 68652055 53455254 52555354 204E6574
  776F726B 3121301F 06035504 0B131868 7474703A 2F2F7777 772E7573 65727472
  7573742E 636F6D31 1F301D06 03550403 13165554 4E2D5553 45524669 7273742D
  48617264 77617265 301E170D 30363034 31303030 30303030 5A170D32 30303533
  30313034 3833385A 3062310B 30090603 55040613 02555331 21301F06 0355040A
  13184E65 74776F72 6B20536F 6C757469 6F6E7320 4C2E4C2E 432E3130 302E0603
  55040313 274E6574 776F726B 20536F6C 7574696F 6E732043 65727469 66696361
  74652041 7574686F 72697479 30820122 300D0609 2A864886 F70D0101 01050003
  82010F00 3082010A 02820101 00C3DD36 CC83C318 55B096D9 1325D326 864838BB
  167FF19F 29F6FD03 F1ED4D26 9A56F0B5 1A1ACDE6 CC855540 A4B5D00D CA22EF3D
  23C67E6C CCBCA1E9 7C5046E0 BD14AD65 12C20B11 69520A07 921F736F C1BAD762
  F0CE002E 34A5C8E6 2F0FEC0D EA446175 68E5E4DC 80364FDA 785D5325 9494F54F
  2E3A606F 0CA6D9B3 F62A2E03 12D52642 0751B264 5771DC21 1C89C769 A3E6FBC2
  7B6EEF0C 87FB5064 E84E4BEF E7719B83 6361C932 8D8CEC14 A7E489AD 3F2B2664
  E48542F2 8950E13A BE15E345 25E25ACB 8C3FE033 1E35095A 84EA7E5D A1F59180
  0A2806B7 CB314125 618B01E9 56A2F63E 5F2FF3C4 43F61994 75834CA1 82423AC6
  BAC40930 A6E17502 51B95E64 8B020301 0001A382 01203082 011C301F 0603551D
  23041830 168014A1 725F261B 28984395 5D0737D5 85969D4B D2C34530 1D060355
  1D0E0416 04143C41 E28F0808 A94C2589 8D6DC538 D0FC858C 6217300E 0603551D
  0F0101FF 04040302 01063012 0603551D 130101FF 04083006 0101FF02 01003019
  0603551D 20041230 10300E06 0C2B0601 0401860E 01020103 01304406 03551D1F
  043D303B 3039A037 A0358633 68747470 3A2F2F63 726C2E75 73657274 72757374
  2E636F6D 2F55544E 2D555345 52466972 73742D48 61726477 6172652E 63726C30
  5506082B 06010505 07010104 49304730 4506082B 06010505 07300286 39687474
  703A2F2F 7777772E 75736572 74727573 742E636F 6D2F6361 63657274 732F5554
  4E416464 54727573 74536572 7665725F 43412E63 7274300D 06092A86 4886F70D
  01010505 00038201 010068AB FCEF806B 18B2B0B3 A34589CB 53C5A2E6 AF08A9FD
  FF0F49AC FFE49FD7 417CA3C5 A2E8AAE0 57212DC3 AA7C0C4C 280B79F4 EE4C32AD
  790E7EA2 5E34184F DF54F1BD 687CE3D3 D7465E6D 64C2F76D 8882730C EF9985EA
  A9EF324A F0839F73 910CA43E 2B3151A6 628F1584 F9A63A12 303FDA6E F8CCC719
  920F5CF4 FE17F195 0847522C 508FE89B A5EEAE70 33899182 FE30AA76 7659D76C
  18D32B12 5B1D281D 7871F6CD 36A2E907 48443BE7 576E820A ADC58ADD E853B471
  AF13D206 9D376D53 3F8A3508 FAFEA216 E6B96F5C 5639D6C6 AAEF1967 CE13C5B8
  9505FB0A 44C99FA9 40254B32 11AF07FE 08D54271 E9E1538B 151FDD2A 07957024
  6F645ED3 B7902E8B 21D8
      quit
crypto pki certificate chain trps1_server
certificate ca 00
  3082029F 30820208 02010030 0D06092A 864886F7 0D010104 05003081 97310B30
  09060355 04061302 55533111 300F0603 55040813 08436F6C 6F726164 6F311030
  0E060355 04071307 426F756C 64657231 16301406 0355040A 130D4369 73636F20
  53797374 656D7331 0C300A06 0355040B 13035354 47311D30 1B060355 04031314
  74727073 312D626C 64722E63 6973636F 2E636F6D 311E301C 06092A86 4886F70D
  01090116 0F777473 75694063 6973636F 2E636F6D 301E170D 30363130 32333230
  32363231 5A170D30 39303731 39323032 3632315A 30819731 0B300906 03550406
  13025553 3111300F 06035504 08130843 6F6C6F72 61646F31 10300E06 03550407
  1307426F 756C6465 72311630 14060355 040A130D 43697363 6F205379 7374656D
  73310C30 0A060355 040B1303 53544731 1D301B06 03550403 13147472 7073312D
  626C6472 2E636973 636F2E63 6F6D311E 301C0609 2A864886 F70D0109 01160F77
  74737569 40636973 636F2E63 6F6D3081 9F300D06 092A8648 86F70D01 01010500
  03818D00 30818902 818100BF F80B7E13 19C5AA37 D7433EDC 4EC5CAD8 40BEE950
  7C099395 997043C9 B9C4BCF6 DF97F091 0ECB7D06 F1B336C6 CD134A67 826B0182
  09535A4B 11EB4BE8 B46187CB BBD9FECB CB03AE65 8F2C5E7E 40A66FF2 899E2FF1
  CBC072B2 A9B537C0 84C9F873 8A141ED9 D8D15186 F7047400 BB8A2CA1 C59DEAD8
  DA09FBB3 6E67D8BF F6811102 03010001 300D0609 2A864886 F70D0101 04050003
  818100AC C6185869 1324F6BD 728A8D00 CEDF15E3 14671016 90ED8F7B 5FF72860
  8F9469D2 B344641D 75E4A566 BCB06ACE 21DFC2B3 041A961C 8A23610A 284BC399
  8E632BBA C734D76A 266E6A45 88DC366F C5E12E9E 087AC3AA 7FEE2089 C97821A7
  882BFEC3 26425299 11700277 B9E4EBCD 15A0B388 F8D4A102 E472A398 63E0D7DA 5BFBE1
      quit
no ip source-route
ip cef
no ip bootp server
ip domain name abi.com
ip name-server 192.168.2.10
no ipv6 cef
parameter-map type urlfpolicy trend cptrendparacatdeny0
allow-mode on
block-page message "The website you have accessed is blocked as per corporate policy"
parameter-map type urlfpolicy trend cptrendparacatdeny1
allow-mode on
parameter-map type urlf-glob cpaddbnwlocparapermit0
pattern facebook.com
parameter-map type urlf-glob cpeditbnwlocparadeny1
parameter-map type urlf-glob cpaddkblocpara2
pattern twitter
parameter-map type urlf-glob cpaddbnwlocparadeny3
parameter-map type trend-global global-param-map
license udi pid CISCO881-SEC-K9 sn FGL1516272A
username abi privilege 15 secret 5 $1$9KCH$sWZmMke.TWMjT5d9njuV/1
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any FULLINET
match protocol http
match protocol https
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type urlfilter match-any cpaddbnwlocclasspermit0
match  server-domain urlf-glob cpaddbnwlocparapermit0
class-map type urlfilter match-any cpaddbnwlocclassdeny3
match  server-domain urlf-glob cpaddbnwlocparadeny3
class-map type inspect match-any -sdminspectclassmap-1
match protocol http
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type urlfilter trend match-any cptrendclasscatdeny0
match  url category Chat-Instant-Messaging
match  url category Nudity
match  url category Pornography
match  url category Social-Networking
match  url category Abortion
match  url category Activist-Groups
match  url category Adult-Mature-Content
match  url category Alcohol-Tobacco
match  url category Gambling
match  url category Games
match  url category Gay-Lesbian
match  url category Internet-Radio-and-TV
match  url category Internet-Telephony
match  url category Intimate-apparel-swimsuit
match  url category Joke-Programs
match  url category Marijuana
match  url category Military
match  url category Personals-Dating
match  url category Sex-education
match  url category Spam
match  url category Weapons
match  url category Violence-hate-racism
class-map type urlfilter trend match-any cptrendclasscatdeny1
class-map type urlfilter match-any cpaddkblocclass2
match  url-keyword urlf-glob cpaddkblocpara2
class-map type urlfilter trend match-any cptrendclassrepdeny1
match  url reputation ADWARE
match  url reputation DIALER
match  url reputation DISEASE-VECTOR
match  url reputation HACKING
match  url reputation PASSWORD-CRACKING-APPLICATIONS
match  url reputation PHISHING
match  url reputation POTENTIALLY-MALICIOUS-SOFTWARE
match  url reputation SPYWARE
match  url reputation VIRUS-ACCOMPLICE
class-map type urlfilter trend match-any cptrendclassrepdeny0
class-map type urlfilter match-any cpeditbnwlocclassdeny1
match  server-domain urlf-glob cpeditbnwlocparadeny1
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect urlfilter cppolicymap-1
parameter type urlfpolicy trend cptrendparacatdeny0
class type urlfilter cpaddbnwlocclassdeny3
  reset
  log
class type urlfilter trend cptrendclasscatdeny0
  reset
  log
class type urlfilter trend cptrendclassrepdeny0
  reset
  log
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
  service-policy urlfilter cppolicymap-1
class type inspect ccp-insp-traffic
  inspect
class class-default
  drop
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
policy-map type inspect urlfilter cppolicymap-2
parameter type urlfpolicy trend cptrendparacatdeny1
class type urlfilter trend cptrendclasscatdeny1
  reset
  log
class type urlfilter trend cptrendclassrepdeny1
  reset
  log
policy-map type inspect ccp-policy-ccp-cls--1
class type inspect -sdminspectclassmap-1
  inspect
  service-policy urlfilter cppolicymap-2
class class-default
  drop
zone security out-zone
zone security in-zone
zone security ccp-inet
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-ccp-inet-out-zone source ccp-inet destination out-zone
service-policy type inspect ccp-policy-ccp-cls--1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
no cdp run
control-plane
banner exec ^CC
