Cisco IOS XE - ip sla auto discovery
dyoma
Hi All
I have Cisco IOS XE Software, Version 16.09.08, ISR4431/K9.
When migrating a configuration from a Cisco 3945 (15.1(1r)T1) to a Cisco ISR4431/K9 (Cisco IOS XE Software, Version 16.09.08), I discovered that there was no "ip sla auto discovery" command. What is the alternative to this command for IOS XE?
It defualt I think
You can sure it there by using
Show run all
See if it appear under correct tunnel interface
MHM
5 Replies 5
dyoma
All of the following commands migrated successfully except "ip sla auto discovery". How to add this command to Cisco IOS XE?
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
ip sla 1
icmp-echo 172.16.200.54 source-ip 172.16.200.53
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 172.16.150.1 source-ip 172.16.150.2
ip sla schedule 2 life forever start-time now
ip sla responder
if you specify source of ip sla echo why you need auto discovery ?
I think the config is correct and not need auto discovery
MHM
dyoma
I really hope you’re right, I’ll test the router in productive mode, thank you!
Please tell me one more thing about DMVPN.
The “ip nhrp map multicast dynamic” command was entered without an error, but I can’t find it in the configuration itself by searching.
interface Tunnel102
  bandwidth 200000
 ip address 172.16.202.1 255.255.255.224
 ip access-group PERMIT_URAN in
 no ip redirects
 ip mtu 1427
 ip nhrp authentication dmvpn
 ip nhrp network-id 99
 ip nhrp holdtime 300
 ip tcp adjust-mss 1385
 ip policy route-map GuestWIFI
 ip ospf cost 60
 load-interval 30
 delay 1000
 tunnel source xxxxxxx
 tunnel mode gre multipoint
 tunnel key 100000
 tunnel protection ipsec profile DMVPN
It defualt I think
Show run all
MHM
Yes, you are right, thank you!!!
