Cisco ISR 1100 Remote Access VPN
Imm
I have Cisco C1121-4P Router with Sec9 License, I need to configure Remote Access VPN - like Anyconnect, is it possible?
hi @Imm i have not done this practically. below document states the configurations for ISR4K. you can reffer if that helps and try in your router too.
Configure AnyConnect SSL VPN for ISR4k with Local Authentication - Cisco
Good luck
KB
Cristian Matei
   Yes you can, given the mentioned license. Here are two guides to help you on achieving that, choose the one that fits your requirements, if it's SSL or IPsec based implementation you're looking for:
https://www.cisco.com/c/en/us/support/docs/security/ios-ssl-vpn/220267-configure-anyconnect-ssl-vpn-for-isr4k-w.html
https://www.cisco.com/c/en/us/support/docs/security/flexvpn/200555-FlexVPN-AnyConnect-IKEv2-Remote-Access.html
Cristian.
ethanncollins93
Yes, you can configure a Remote Access VPN on the Cisco C1121-4P router. With the Security 9 license, it supports AnyConnect VPN, but you’ll need to ensure the correct VPN configuration is applied, including user authentication and certificate setup. If you want, I can outline the basic steps to get it up and running.
