Cisco ISR4431 boost licence removal
James Simpson
Beginner
Beginner
Is it possible to uninstall the Boost licence on a Cisco ISR4431 please ?
Many thanks
 Routing, Branch Route
James Simpson
Moaz.Elzhrawey
Beginner
Beginner
Use the no platform hardware throughput level boost command to disable the functionality.
Note#
The command is removed from the configuration, but the license is released only after the device is reloaded.
The throughput level does not take effect until the device is reloaded.
The license visibility is available till the device is reloaded..
*** Please rate this as helpful and correct answer if it solved your problem. ***
Moaz Elzhrawey
Solutions Architect, CCIE 2x RS | DC, VCP 3x NV | DCV | DTM
+966 596822551
Moaz.Elzhrawey
Beginner
Beginner
Note#
Moaz Elzhrawey
+966 596822551
Thank you
Recognize Your Peers
