07-07-2022 04:09 AM
I am facing weird issue. There is no option to take the calls in cisco jabber. Attach you can see the screenshot.
Any idea about this issue?
Thank You,
Kamal Puri
Solved! Go to Solution.
07-07-2022 05:07 AM
Jabber is installed in Windows Laptop. But this issue is not always. Reset jabber fix the problem. But is wondering what could be the reason.
Thank You,
Kamal Puri
07-07-2022 04:57 AM
very odd (as you obviously need the Answer/Decline option in the pop up window. What devices is this installed on ?
07-07-2022 05:07 AM
Thank You,
Kamal Puri
07-07-2022 05:44 AM
are these Windows 10 or 11 clients ? With the latest Jabber release (Release 14.1(1)) ?
07-07-2022 07:22 AM - last edited on 07-21-2022 12:17 AM by Translator
Hi @Georg Pauwen ,
jabber version: Version 12.8.1.52494 Build 302494.
Not sure on which windows version.
07-07-2022 08:08 AM
can you get your hands on 14.1(1) ? If so, try that (latest) release...
