r.sagredo
Beginner
cisco license trial C1921...EasyVPN
Currently. we have this license:
T
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security        None                None           None
data              None                None           None
we need to configure vpn (EasyVPN) on a router 1921 ... My question is: I  can download a demo IOS that allows me to do this setup?. What is the procedure?
Gracias.
Router# show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 26-Jul-12 19:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Router uptime is 1 week, 6 days, 5 hours, 17 minutes
System image file is "usbflash0:c1900-universalk9-mz.SPA.152-4.M1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID F
2 Gigabit Ethernet interfaces
3 terminal lines
2 Cellular interfaces
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          FTX
data          None          None           None
Router#
1 REPLY 1
paolo bevilacqua
Hall of Fame Master
You can enable temporary security license, and to know how to do that, you can search cisco.com, or this forum.
