Cisco NCS VRF Route Leaking
johnlloyd_13
Level 9
Level 9
hi,
i got a cisco NCS540 and would need to import/export or do a "route leaking" between two VRFs.
this is the config in an IOS-XE router:
ip vrf SDWAN
 rd 65000:210
 route-target export 65000:210
 route-target import 65000:210
 route-target import 65000:209
can someone confirm which config is the correct or should use in IOS-XR?
vrf SDWAN
rd 65000:210
address-family ipv4 unicast
import route-target 65000:210
import route-target 65000:209
export route-target 65000:210
OR
vrf SDWAN
 rd 65000:210
Harold Ritter
Hi @johnlloyd_13 ,
This would be the correct IOS-XR format:
vrf SDWAN
rd 65000:210
Harold Ritter
Hi @johnlloyd_13 ,
vrf SDWAN
rd 65000:210
johnlloyd_13
Level 9
Level 9
thank you sir! appreciate it
You are very welcome @johnlloyd_13 and thanks for the feedback
