Cisco PA-GE 7206VXR 7204VXR Gigabit Ethernet Module
Andrew Schulz
I have a 7204VXR and I purchased two Cisco PA-GE 7206VXR 7204VXR Gigabit Ethernet Module. I plugged them in but I am not seeing them as an interface (show ip interface brief). It doesn't appear that they are being recognized or powering on. Do I need to enable these in config?
Hello Andrew,
your router has an NPE 225 with already  3 PA FE.
also the document we are looking provides a table for NPE-225 and the PA-GE is not listed there
So I'm afraid you would need a better NPE
Hope to help
Giuseppe
7 Replies 7
Leo Laohoo
Maybe you've exceeded the allowed Bandwidth Points?
Cisco 7200 Bandwidth Points
Giuseppe Larosa
Hello Andrew,
post a show c7200
depending on the NPE model, and if there is an I/O controller the use of PA-GE is possible.
It might be possible that NPE-G1 and NPE-G2 that have built-in GE ports and that can work without the I/O controller (they include one on the board) do not support PA GE.
this is my guess on a C7200 with NPE-G1 or NPE-G2 you should use only the built in GE ports, a PA GE would have worse performance going on the bus(es) as explained in the link provided by Leo
Hope to help
Giuseppe
Thanks for the help. Here is the show c7200...
Also, I found on the the following link this... I agree with leo that I may have exceeded the bandwidth points.
What are my options?
1-port full-duplex Gigabit Ethernet
PA-GE
Not supported
400
0.24 MB
http://www.cisco.com/en/US/docs/routers/7200/configuration/7200_port_adapter_config_guidelines/3875In.html#wp1100537
core#sh c7200
Network IO Interrupt Throttling:
throttle count=0, timer count=0
active=0, configured=0
netint usec=3999, netint mask usec=200
Midplane EEPROM:
        Hardware revision 2.11          Board revision A0
        Serial number     34124007      Part number    73-3905-11
        Test history      0x0           RMA number     00-00-00
        MAC Pool Size     1024          MAC Addr Base  0016.c86a.d400
        Chassis Model     0x4
        EEPROM format version 1
        EEPROM contents (hex):
          0x00: 01 04 02 0B 02 08 B0 E7 49 0F 41 0B 00 16 C8 6A
          0x10: D4 00 04 00 00 00 00 00 05 10 20 50 00 00 FF 00
          0x20: 00 00 00 00 63 79 08 2C 63 55 00 00 60 7B C2 80
          0x30: 63 72 00 00 00 00 00 00 00 00 00 00 63 79 08 2C
C7204VXR CPU EEPROM:
        Hardware revision 1.8           Board revision A0
        Serial number     34275524      Part number    73-3453-09
          0x00: 01 C2 01 08 02 0B 00 C4 49 0D 7D 09 00 00 00 00
          0x10: 50 00 00 00 05 12 15 00 00 00 FF FF FF FF FF FF
C7204VXR PE EEPROM:
        Hardware revision 1.2           Board revision E0
        Serial number     34275735      Part number    73-4043-02
          0x00: 01 D5 01 02 02 0B 01 97 49 0F CB 02 00 00 00 00
          0x10: 70 00 00 00 05 12 14 00 00 00 FF FF FF FF FF FF
TLB entries (38/48 used):
Virt Address range      Phy Address range         Attributes
0x4B000000:0x4B1FFFFF   0x14B000000:0x14B1FFFFF   CacheMode=2, RW, Invalid
0x4B200000:0x4B3FFFFF   0x14B200000:0x14B3FFFFF   CacheMode=2, RW, Invalid
0x10000000:0x10001FFF   0x100000000:0x100001FFF   CacheMode=2, RW, Valid
0x40000000:0x41FFFFFF   0x040000000:0x041FFFFFF   CacheMode=2, RW, Valid
0x44000000:0x45FFFFFF   0x044000000:0x045FFFFFF   CacheMode=2, RW, Valid
0x3C000000:0x3C7FFFFF   0x048000000:0x0487FFFFF   CacheMode=2, RW, Valid
0x3C800000:0x3CFFFFFF   0x01F000000:0x01F7FFFFF   CacheMode=2, RW, Invalid
0x3D000000:0x3D7FFFFF   0x04D000000:0x04D7FFFFF   CacheMode=2, RW, Valid
0x3D800000:0x3DFFFFFF   0x01F000000:0x01F7FFFFF   CacheMode=2, RW, Invalid
0x3E000000:0x3E7FFFFF   0x04D800000:0x04DFFFFFF   CacheMode=2, RW, Valid
0x3E800000:0x3EFFFFFF   0x049800000:0x049FFFFFF   CacheMode=2, RW, Invalid
0x3F000000:0x3F7FFFFF   0x04E000000:0x04E7FFFFF   CacheMode=2, RW, Invalid
0x1FC00000:0x1FC7FFFF   0x01FC00000:0x01FC7FFFF   CacheMode=2, RO, Valid
0x1E000000:0x1E1FFFFF   0x01E000000:0x01E1FFFFF   CacheMode=2, RW, Valid
0x1E800000:0x1E9FFFFF   0x01E800000:0x01E9FFFFF   CacheMode=2, RW, Valid
0x60000000:0x61FFFFFF   0x000000000:0x001FFFFFF   CacheMode=3, RO, Valid
0x62000000:0x6201FFFF   0x002000000:0x00201FFFF   CacheMode=3, RO, Valid
0x62020000:0x6203FFFF   0x002020000:0x00203FFFF   CacheMode=3, RO, Valid
0x62040000:0x6205FFFF   0x002040000:0x00205FFFF   CacheMode=3, RO, Valid
0x62060000:0x62067FFF   0x002060000:0x002067FFF   CacheMode=3, RO, Valid
0x62068000:0x6206FFFF   0x002068000:0x00206FFFF   CacheMode=3, RO, Valid
0x62070000:0x62077FFF   0x002070000:0x002077FFF   CacheMode=3, RW, Valid
0x62078000:0x6207FFFF   0x002078000:0x00207FFFF   CacheMode=3, RW, Valid
0x62080000:0x620FFFFF   0x002080000:0x0020FFFFF   CacheMode=3, RW, Valid
0x62100000:0x6217FFFF   0x002100000:0x00217FFFF   CacheMode=3, RW, Valid
0x62180000:0x621FFFFF   0x002180000:0x0021FFFFF   CacheMode=3, RW, Valid
0x62200000:0x623FFFFF   0x002200000:0x0023FFFFF   CacheMode=3, RW, Valid
0x62400000:0x625FFFFF   0x002400000:0x0025FFFFF   CacheMode=3, RW, Valid
0x62600000:0x627FFFFF   0x002600000:0x0027FFFFF   CacheMode=3, RW, Valid
0x62800000:0x62FFFFFF   0x002800000:0x002FFFFFF   CacheMode=3, RW, Valid
0x63000000:0x637FFFFF   0x003000000:0x0037FFFFF   CacheMode=3, RW, Valid
0x63800000:0x63FFFFFF   0x003800000:0x003FFFFFF   CacheMode=3, RW, Valid
0x64000000:0x65FFFFFF   0x004000000:0x005FFFFFF   CacheMode=3, RW, Valid
0x66000000:0x67FFFFFF   0x006000000:0x007FFFFFF   CacheMode=3, RW, Valid
0x07000000:0x077FFFFF   0x007000000:0x0077FFFFF   CacheMode=2, RW, Valid
0x07800000:0x07FFFFFF   0x007800000:0x007FFFFFF   CacheMode=2, RW, Valid
0x77000000:0x777FFFFF   0x007000000:0x0077FFFFF   CacheMode=0, RW, Valid
0x77800000:0x77FFFFFF   0x007800000:0x007FFFFFF   CacheMode=0, RW, Valid
It is normal operation to have both Valid and Invalid TLB entries.
System was restarted by power-on at 05:53:56 PDT Thu Jun 22 2006
0 spurious cache errors detected.
System Controller Network Interrupts
Wrapper is NOT installed
Registered Interrupts:
Level Mask               Count      Data       Interrupt Handler
Hello Andrew,
unfortunately it is not possible to understand the type of NPE, may you add a sh version?
the document you have linked says that BW calculation points for 1 PA GE is 400 points.
It is not clear however, if there are special cases/combinations.
Hope to help
Giuseppe
core#sh ver
IOS (tm) 7200 Software (C7200-JS-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 12-Dec-05 19:13 by evmiller
Image text-base: 0x60008AF4, data-base: 0x62070000
ROM: System Bootstrap, Version 12.2(4r)B3, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(6f), RELEASE SOFTWARE (fc1)
core uptime is 1 day, 2 hours, 2 minutes
System restarted at 03:16:53 PDT Tue Jul 12 2011
System image file is "disk0:c7200-js-mz.123-17a.bin"
cisco 7204VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memor        y.
Processor board ID 34124007
R527x CPU at 262MHz, Implementation 40, Rev 10.0, 2048KB L2 Cache
4 slot VXR midplane, Version 2.11
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
Number of Fast PAs = 3
Number of Fast+Medium PAs = 3
Total number of PA bandwidth points consumed = 490
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
4 FastEthernet/IEEE 802.3 interface(s)
25 Serial network interface(s)
1 Channelized T3 port(s)
125K bytes of non-volatile configuration memory.
62976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Hello Andrew,
Hope to help
Giuseppe
Thank you Giuseppe, that's what my conclusion was as well. I will look at getting a better NPE.
Thanks again...
