CISCO PIX 501 Problem
NWUpgrades
I recently purchased a used PIX 501 only to find that it does not have the PDM software. It is running OS ver 6.1, but when typing in https:192.168.1.1 I can not get to the PDM but I am able to ping the IP address. ANy suggestions on where to get the PDM software and how to install it would be greatly appreciated.
guruprasadr
Level 7
Level 7
HI,
Ensure that you have a Cisco Connection Online (CCO) account. You need a CCO username and password to download PDM software. If you do not have a CCO account, go to http://tools.cisco.com/RPF/register/register.do and enter the information requested.
PLS RATE if HELPS.
Best Regards,
Guru Prasad R
robert.horrigan
Level 2
Level 2
It may have PDM. Type /pdm ,also make sure that you allow https access in the cli to from your subnet
dongdongliu
if you want to download PDM soft from cisco.com, be careful of PDM v1.1 is supported by PIX OS 6.1
