Cisco Power Adapter for Cisco 819 Hardened Dual Radio 802.11n WiFi Integrated Services Routers
ttvo
Beginner
Beginner
Hi Everyone,
I am asking for your help.
I recently purchased one Cisco power adapter sold by Cisco on Amazon.com.
The power adapter is for my Cisco Cisco 819 Hardened Dual Radio 802.11n WiFi Integrated Services Routers.
Unfortunately, the Cisco power adapter does not come with a two-pole straight blade plug. The two poles straight blade plug is the end that plugs into an electrical outlet. Please see the attached picture.
I need to purchase the compatible two poles straight blade plug only to connect it to the power adapter so it can be used.
Any suggestions to resolve my issue greatly appreciated.
Thank you!
TV
That is because of the DHCP worker issues. One reason for purchasing this switch was for security highlights. Indeed, reconsider my companion. The authorized security highlights are preliminaries and what is more awful since this item is more seasoned, the preliminaries are now outdated.
  1. The expense is awesome
  2. 4 Gigabit Ethernet router Ports
  3. Double WAN is a reward
  4. Ideal for a home with no switch.
  5. Awful Management UI toward the beginning (Update firmware improve it)
Recognize Your Peers
