Cisco PVST interoperability with Avaya Switch
jordontin
I have cisco switch STP mode now running as PVST, may I know the how to make sure Avaya STP can interoperability with Cisco STP.
Reza Sharifi
It should work fine. Avaya switches support both STP and RSTP.
Hi Reza,
Which STP mode should configure on Avaya switch?
Hi Jordon,
As Reza said it depends on you. AS Avaya switches supports both legacy STP and RSTP you can decide which you would want to be run on this device.
Please find below link configuring STP on avaya.
1-
http://www.scribd.com/doc/43738163/Avaya-Cisco-Interoperability-Technical-Config-Guide
2-
http://198.152.212.23/css/P8/documents/100095193
Inayath
