System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 98304 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x403b9c
monitor: command "boot" aborted due to user interrupt
rommon 1 > dir flash:
File size Checksum File name
4209848 bytes (0x403cb8) 0xbdf3 c2600-i-mz.120-7.bin
rommon 2 > boot flash:c2600-is-mz.123-6c.bin
open: file "c2600-is-mz.123-6c.bin" not found
open(): Open Error = -1
loadprog: error - on file open
boot: cannot load "flash:c2600-is-mz.123-6c.bin"
rommon 3 > dir flash:c2600-i-mz.120-7.bin
monitor: command "dir" not found
rommon 4 > boot flash:c2600-i-mz.120-7.bin
rommon 1 > IP_ADDRESS=192.168.1.2
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=192.168.1.3
rommon 4 > TFTP_SERVER=192.168.1.1
rommon 5 > TFTP_FILE=c2600-is-mz.123-15a.bin
rommon 6 > tftpdnld
IP_ADDRESS: 192.168.1.2
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.1.3
TFTP_SERVER: 192.168.1.1
TFTP_FILE: c2600-is-mz.123-15a.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
PHY did not complete auto-negotation, status = 0x100
ARP: address resolution for 192.168.1.1 timed out.
ARP failed with failure code 1. TFTP transfer aborted.
TFTP: Operation terminated prematurely.
