Cisco router not accepting wan ip address with DHCP
cmsmallegan
Since last night my 1941 router hasn't been addressed a ip.
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1941/K9 sn ***********
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.0.0.1 255.255.0.0
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address dhcp
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
snmp-server community public RO
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password kAPD2j2rsj
login
transport input none
scheduler allocate 20000 1000
end
luis_cordova
Hi @cmsmallegan ,
What is the result of the command show ip interface g0/1?
In theory, it is with that command that you can review the ip assigned by DHCP:
Yeah I just realized that my other interface was hosting a 10.0.0.0 network while interface 0/0 was trying to connect to a 10.0.0.0 Network, thank you sorry about that.
Edwin Portillo
Hi @cmsmallegan,
You should check how you are connected and which is the correct interface because apparently the g0/1 interface is the one configured to receive DHCP.
As @luis_cordova  says you could check with the command: show ip interface g0/1.
