Cisco SG550 - Switch - Stack Configuration
Yasmeen
Hi Team,
          I Have connected Stack cable between two Cisco SG550 Switches,
          How do i confirm which switch is Master switch and which one in Slave ?
          Can u List the commands to check Stack configuration
          If i power off the Master Switch  - my Data Traffic automatically not going via slave switch
          https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350x-series-stackable-managed-switches/smb5408-configure-stack-settings-on-an-sg350x-switch.html
       Using This switch only i configured my switches
      My Issue is - My data traffic is not going via redundancy switch ?
      what is the main use of Stack Cable ?
switchf8fa54#show stack link details
Topology is Chain
UNIT ID Link Status Speed Neighbor Neighbor Neighbor
Unit ID Link MAC Address
1 te3 Active 10G 2 te4 40:a6:e8:f8:fa:54
1 te4 Active 10G 2 te3 40:a6:e8:f8:fa:54
2 te3 Active 10G 1 te4 40:a6:e8:f8:f9:15
2 te4 Active 10G 1 te3 40:a6:e8:f8:f9:15
switchf8fa54#show stack configuration
Unit Id After Reboot Configuration
Unit Id Stack Links
1 Auto te3-4
2 Auto te3-4
This is My master switch Running Config
switchf8fa54#show running-config
config-file-header
switchf8fa54
v2.5.0.83 / RTESLA2.5_930_364_091
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink te
unit-type unit 2 network gi uplink te
unit-type unit 3 network gi uplink te
unit-type unit 4 network gi uplink te
unit-type unit 5 network gi uplink te
unit-type unit 6 network gi uplink te
unit-type unit 7 network gi uplink te
unit-type unit 8 network gi uplink te
unit-type-control-end
vlan database
vlan 2-12
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
no boot host auto-config
no boot host auto-update
bonjour interface range vlan 1
hostname switchf8fa54
username admin password encrypted 7af2d10b73ab7cd8f603937f7697cb5fe432c7ff privilege 15
clock timezone J 0 minutes 0
no clock source sntp
interface vlan 2
ip address 192.168.137.2 255.255.255.128
interface vlan 3
ip address 192.168.137.130 255.255.255.128
interface vlan 4
ip address 192.168.134.2 255.255.254.0
interface vlan 5
ip address 192.168.128.2 255.255.252.0
interface vlan 6
ip address 192.168.132.2 255.255.254.0
interface vlan 7
ip address 192.168.136.2 255.255.255.128
interface vlan 8
ip address 192.168.136.130 255.255.255.128
interface vlan 9
ip address 192.168.138.2 255.255.255.128
interface vlan 10
ip address 192.168.138.129 255.255.255.192
interface vlan 11
ip address 192.168.138.194 255.255.255.192
interface GigabitEthernet1/0/1
ip address 192.168.139.66 255.255.255.248
no switchport
interface GigabitEthernet1/0/2
spanning-tree link-type point-to-point
switchport mode trunk
switchport access vlan 2
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
interface GigabitEthernet1/0/3
switchport access vlan 3
interface GigabitEthernet1/0/4
switchport access vlan 4
interface GigabitEthernet1/0/5
switchport access vlan 5
interface GigabitEthernet1/0/6
switchport access vlan 6
interface GigabitEthernet1/0/7
macro description "switch "
interface GigabitEthernet1/0/8
switchport access vlan 8
interface GigabitEthernet1/0/9
switchport access vlan 9
interface GigabitEthernet1/0/10
switchport access vlan 10
interface GigabitEthernet2/0/7
exit
ip default-gateway 192.168.139.65
ip route 192.168.128.0 /22 192.168.139.65
ip route 192.168.132.0 /23 192.168.139.65
ip route 192.168.134.0 /23 192.168.139.65
ip route 192.168.136.0 /25 192.168.139.65
ip route 192.168.136.128 /25 192.168.139.65
ip route 192.168.137.0 /25 192.168.139.65
ip route 192.168.137.128 /25 192.168.139.65
ip route 192.168.138.0 /25 192.168.139.65
ip route 192.168.138.128 /26 192.168.139.65
ip route 192.168.138.192 /26 192.168.139.65
Pls help to complete my setup
0 Replies 0
