03-04-2015 01:45 AM - edited 03-05-2019 12:56 AM
After configuring two routers in order to configure VPN command show crypto isakmp sa showing nothing. Please help what am i missing.
hostname R1-2801
boot-start-marker
boot-end-marker
enable secret 5 $1$dbvq$s4Mk.nyB4nIhOC7wQqji.1
no aaa new-model
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
crypto isakmp policy 10
authentication pre-share
crypto isakmp key 6 vpnkey address 192.168.1.12
crypto ipsec transform-set vpnset esp-aes esp-sha-hmac
crypto map vpnset 10 ipsec-isakmp
set peer 192.168.1.12
set transform-set vpnset
match address 100
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.11 255.255.255.0
duplex auto
speed auto
crypto map vpnset
interface Serial0/1/0
no ip address
shutdown
no fair-queue
clock rate 2000000
ip forward-protocol nd
ip http server
no ip http secure-server
access-list 100 permit ip 10.10.10.0 0.0.0.255 10.10.11.0 0.0.0.255
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
hostname R2-1841
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
controller E1 0/0/0
crypto isakmp key 6 vpnkey address 192.168.1.11
set peer 192.168.1.11
match address 100
ip address 10.10.11.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.1.12 255.255.255.0
duplex auto
speed auto
crypto map vpnset
ip http server
disable-eadi
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
end
R2-1841#
Nooruddin
03-04-2015 05:16 AM
The crypto ACL on R2 is wrong, it has to be:
access-list 100 permit ip 10.10.11.0 0.0.0.255 10.10.10.0 0.0.0.255
And if it will be for production and not only for learning, consider migrating to Virtual Tunnel Interfaces (VTI).
10-28-2015 04:54 AM
Hello
Sorry for very prolonged reply. thanks i will check and update and then rate it.
I apologize again.
03-06-2015 05:56 PM
There are a number of things missing from the config to create the VPN between the routers. I'm going to reference you to a know working walk through. This will give you everything you need to get this working.
Cheers,
Sam
03-07-2015 12:15 AM
Your link is for DMVPN which really doesn't make any sense for a VPN between two routers.
