05-17-2022 02:38 AM
I wanted to know if the limitation included in this article is still true.
https://community.cisco.com/t5/security-documents/asa-wccp-step-by-step-configuration/ta-p/3126636
This is the limitation:
The only topology that the adaptive security appliance supports is when client and cache engine are behind the same interface of the adaptive security appliance and the cache engine can directly communicate with the client without going through the adaptive security appliance.
Solved! Go to Solution.
05-17-2022 02:56 AM
Yes as per my testing Lan 9.12 code i see same results. (that was my lab)
in real world user IP address space will be always different.
05-17-2022 02:56 AM
05-17-2022 03:01 AM - edited 05-17-2022 03:02 AM
So I can have clients on a Vlan and WCCP server on a different VLAN, as long as they are both behind the same interface of the ASA, right?
05-17-2022 03:34 AM
yes that should work as expected.
