Cisco WS-C4900M high cpu multicast
Maksim Sandakov
Good afternoon
I have Cisco 7606 as core(with directly connected multicast sources, configured as RP) and few 4900M connected in ring, and few l3 switches with customers connected to 4900. OSPF+PIM-SM.
Multicast traffic working in all network, but on only one switch we have very high cpu usage(~80%) with Cat4k Mgmt HiPri and  K5CpuMan Review processes.
When i used debug on cpu i see that
42 days 9:41:26:513252 - RxVlan: 1013, RxPort: Te1/8
Priority: High, Tag: No Tag, Event: L3 Forward, Flags: 0x40, Size: 1362
Eth: Src 68:EF:BD:B5:F1:BF Dst 01:00:5E:7F:05:C5 Type/Len 0x0800
Ip: ver:IpVersion4 len:20 tos:192 totLen:1344 id:0 fragOffset:0 ttl:19 proto:udp
    src: 172.16.255.6 dst: 239.255.5.197 firstFragment lastFragment
Where Te1/8 is uplink port.
But when i check ip mroute i see group with output interface(and its working) but without (S,G) entry
(*, 239.255.5.102), 00:00:43/00:02:46, RP 172.23.176.252, flags: S
  Incoming interface: TenGigabitEthernet1/8, RPF nbr 172.23.176.69
  Outgoing interface list:
    TenGigabitEthernet1/1, Forward/Sparse, 00:00:43/00:02:46
Then i launched PIM debug and have two situations:
1) With (S,G) entry
PIM(0): Received v2 Join/Prune on TenGigabitEthernet1/4 from 172.23.177.114, to us
PIM(0): Join-list: (*, 239.255.2.19), RPT-bit set, WC-bit set, S-bit set
PIM(0): Update TenGigabitEthernet1/4/172.23.177.114 to (*, 239.255.2.19), Forward state, by PIM *G Join
PIM(0): Update TenGigabitEthernet1/4/172.23.177.114 to (172.16.2.250, 239.255.2.19), Forward state, by PIM *G Join
PIM(0): Join-list: (172.16.2.250/32, 239.255.2.19), S-bit set
PIM(0): Update TenGigabitEthernet1/4/172.23.177.114 to (172.16.2.250, 239.255.2.19), Forward state, by PIM SG Join
2) Without (S,G) entry
PIM(0): Received v2 Join/Prune on TenGigabitEthernet1/2 from 172.23.178.130, to us
PIM(0): Join-list: (*, 239.255.40.232), RPT-bit set, WC-bit set, S-bit set
PIM(0): Check RP 172.23.176.252 into the (*, 239.255.40.232) entry
PIM(0): Building Triggered (*,G) Join / (S,G,RP-bit) Prune message for 239.255.40.232
PIM(0): Add TenGigabitEthernet1/2/172.23.178.130 to (*, 239.255.40.232), Forward state, by PIM *G Join
PIM(0): Insert (*,239.255.40.232) join in nbr 172.23.176.69's queue
PIM(0): Update TenGigabitEthernet1/2/172.23.178.130 to (*, 239.255.40.232), Forward state, by PIM *G Join
PIM(0): Building Join/Prune packet for nbr 172.23.176.69
PIM(0):  Adding v2 (172.23.176.252/32, 239.255.40.232), WC-bit, RPT-bit, S-bit Join
PIM(0): Send v2 join/prune to 172.23.176.69 (TenGigabitEthernet1/8)
How can i solve this problem? Software version on all 4900m 15.1(2)SG(except one neighbor with 12.2(53)SG1)
I can't tell from what you are saying if your 4900 does inter-Vlan routing ? Try and disable proxy arp (no ip proxy-arp) and ip redirects (no ip redirects) on the Vlan interfaces (of either the 4900, or the neighboring L3 switch(es) connected to the 4900.
Thank you for reply
Between 4900 and other l3 switches only ip interfaces. I tried disable ip redirects(proxy arp disabled already), but it didnt help.
Maksim Sandakov
Somebody? There is scheme, problem with Core2.
